Sharepoint Thumbmail not diplaying - Reserved
2023-09-25T13:13:37+00:00
Hi all,
I don't know what has happened. It was working fine and then with no reason stopped.
I was using powerapps to upload some pictures for the list items into Thumbmail / Image column. It was working fine. Now it doesn't. And even when I try to add it manually from sharepoint lists view it doesn't work either.
That's what it displays now and at the bottom you can see it was working on previous ones (about 3-4 weeks ago).
I have also noticed change in the link structure, but I haven't changed a single thing. Can somebody explain why is that not working anymore? I needed it urgently today...
![](https://learn-attachment.microsoft.com/api/attachments/3ad7847b-6306-4fef-b79f-6b2983fc2a70?platform=QnA
Microsoft 365 and Office | SharePoint | For business | Other
    2024-01-12T06:21:33+00:00
    IS there any solution suggested by Microsoft for this issue.
    2024-01-17T15:53:49+00:00
    It worked for me without having to change the attachment settings. When I renamed the photo file that I am uploading it worked fine.
    2024-01-18T12:33:59+00:00
    Hi all,
    We have the same problems with all Sharepoint lists ;(
    Is there any news about it or maybe solution.
    2024-01-21T09:55:37+00:00
    Hi all,
    Update?
    2024-01-22T06:42:56+00:00
    Hi all,
    I use this formatting. I look forward to Microsoft solving the problem :)
      "$schema": "https://developer.microsoft.com/json-schemas/sp/v2/column-formatting.schema.json",
      "elmType": "div",
      "style": {
        "display": "=if(@currentField,'block','none')",
        "overflow": "hidden",
        "margin": "8px auto -3px -4px",
        "cursor": "pointer"
      "children": [
          "elmType": "img",
          "attributes": {
            "src": "=getThumbnailImage(@currentField, 200, 200)"
          "style": {
            "position": "relative",
            "top": "50%",
            "margin-top": "10px",
            "width": "200px"
