Sharepoint Thumbmail not diplaying - Reserved
2023-09-25T13:13:37+00:00
Hi all,
I don't know what has happened. It was working fine and then with no reason stopped.
I was using powerapps to upload some pictures for the list items into Thumbmail / Image column. It was working fine. Now it doesn't. And even when I try to add it manually from sharepoint lists view it doesn't work either.
That's what it displays now and at the bottom you can see it was working on previous ones (about 3-4 weeks ago).
I have also noticed change in the link structure, but I haven't changed a single thing. Can somebody explain why is that not working anymore? I needed it urgently today...
![](https://learn-attachment.microsoft.com/api/attachments/3ad7847b-6306-4fef-b79f-6b2983fc2a70?platform=QnA
Microsoft 365 and Office | SharePoint | For business | Other
    2024-06-13T19:55:59+00:00
    Actually I did... even on the second layer bin. It is not there anymore... and when I try to open the link: {"error":{"code":"itemNotFound","message":"Attachment not found."}}
    2024-07-24T14:42:41+00:00
    Hi João, i have a similar problem, did you managed to find a solution?
    2024-10-21T09:29:18+00:00
    We have the same problem that started late last week.
    • A SharePoint List has an Image type column for uploading a photo and we use Attachments to upload supporting documentation. Now when adding a photo (via the Power App on top, or via Lists) it is saved and displayed as Reserved_ImageAttachment_* in the Attachments list. Now it displays in the Photo (Image) field too, though that wasn't initially the case the first time we spotted this.
    • In the List itself I cannot see the image in the Attachments list, despite it displaying as an Attachment in the App. This is misleading.
    • The image thumbnails also began displaying very blurrily in the App but that seems fixable with ThisItem.Photo.Full.
    • The image URLs have also changed in the manner described; we don't use the URL in automations but browse/access the images via Site Contents > Site Assets > Lists > [relevant list folder] (e.g. for batch downloading), and the new image no longer appears there - I haven't yet found it by navigating in the SharePoint web interface at all so am keen to understand where they now sit so we can still access them in batch too. Any pointers please?
    • The blurry display of images was also the case for a second app that uses an Image type column but doesn't use/display the Attachments column in the App - I've disabled Attachments but of course lost the recent images that will need re-uploading. After uploading new images, they are saved again in the usual Site Assets > Lists folder.
    2024-10-23T11:56:53+00:00
    Gina please open a technical support request like we did, images are saved as attachments and no longer in the Assets library.
    The same thing happens to us as you since late last week, they have made changes without warning and changes for the worse in Sharepoint.
    We continue using it, I don't know why they want to end it.
    If there are no tickets there are no resources to resolve, this is how Microsoft works
    2024-12-05T03:54:56+00:00
    when you disable and then able it again, did the picture download can change into image instead of its link??
