How to build an ODBC Connection
2023-07-13T21:47:21+00:00
Now that we have a folder with all of the images, How do I connect to it;
Use the query Wizard?
Where do I find the Data Connection Wizzard?
The name of my folder on the C: Drive is NEPhotos
Can I do it with a SQL statement
I have searched around for where and how to do it, but so far got nowhere.
Thanks Again Guys.
Old NASA Kid
Microsoft 365 and Office | Access | For business | Windows
Duane Hookom 26,935 Reputation points Volunteer Moderator
2023-07-17T13:32:34+00:00
In all honesty we have never been made aware of project requirements, statement of purpose, scope, number of users, security, how the application needs to be updated and distributed, how data changes will be handled, etc. I have asked but never been answered. How can we get you somewhere when we really have no idea of where you are going. It's like we are in the back seat of a car offering directions without a clear understanding of our final destination. We know full well how to drive and shift and obey traffic laws and navigate but the drive often makes the same mistakes, doesn't seem to hear, plays the radio too loud and doesn't respond. Apparently the driver knows how to drive a tractor in a field but we are in a nearly self-driving car.
I have also suggested several times that based on your need for distributing this application across many locations with limited resources and who knows what age of computer, you should consider a web based application. This would allow for instant updates to all users worldwide, You could restrict access if needed. There would be absolutely no cost to any end user unless you wanted to charge a subscription. Images would be available to all users as long as they had a computer, tablet, or phone connected to the internet. No installing anything anywhere.
If you want to continue down the Access path, please consider creating one new thread with the information I suggested in the first sentence above. Also provide what you currently have which I believe is thousands of images.
2023-07-16T21:14:38+00:00
I re-vitalized an old form, with two jpg-files:
For future use, you can even enlarge the pictures using the Zoom+ button:
So, in principle it works, but only with a valid file-specification.
Imb.
2023-07-16T20:19:59+00:00
Me.Image25.Picture = strFile ?????????????
Hi T.Z.,
If strFile contains the full filespecification, including drive and filetype, it should work
Imb.
74 additional answers
  1. George Hepworth 23,120 Reputation points Volunteer Moderator
    2023-07-27T23:45:15+00:00
    Yes, as I said, your code retrieves the dimensions (height and width) of the image control, not the size of the image in that control.
    If you want the size of the image itself, use a different method. Retrieve that information directly from the image file.
    I suggest you acquire this tool for that purpose.
    2023-07-28T00:06:29+00:00
    We got it! Here is the code that worked.
                        Me.Image25.Visible = False
                        Me.Image25.Picture = HoldPath
                        ImgWdth = Me.Image25.ImageWidth
                        ImgHgth = Me.Image25.ImageHeight
                        Me.Image25.Visible = True
                        rst.Edit
                            rst!Photosize = ImgWdth + ImgHgth
                        rst.Update
    When you use .Visible = False it changes something
    I am not sure Microsoft wanted it this way, but it works. After you get the number that is not bound to the Image, then you display the image again.
    Now I have the file with the smallest whatever number I have so I can find the smallest image. Now all we have to do is wait for the Pakistan file and that will be our final test.
    J. J. just came in and said try this and it worked. It is good because he is not an Access fan.
    As soon as I can try it with the Pakistani file and it works, we will close this baby out!
    Time for a beer!
    T. Z.
