How to build an ODBC Connection
2023-07-13T21:47:21+00:00
Now that we have a folder with all of the images, How do I connect to it;
Use the query Wizard?
Where do I find the Data Connection Wizzard?
The name of my folder on the C: Drive is NEPhotos
Can I do it with a SQL statement
I have searched around for where and how to do it, but so far got nowhere.
Thanks Again Guys.
Old NASA Kid
Microsoft 365 and Office | Access | For business | Windows
Duane Hookom 26,935 Reputation points Volunteer Moderator
2023-07-17T13:32:34+00:00
In all honesty we have never been made aware of project requirements, statement of purpose, scope, number of users, security, how the application needs to be updated and distributed, how data changes will be handled, etc. I have asked but never been answered. How can we get you somewhere when we really have no idea of where you are going. It's like we are in the back seat of a car offering directions without a clear understanding of our final destination. We know full well how to drive and shift and obey traffic laws and navigate but the drive often makes the same mistakes, doesn't seem to hear, plays the radio too loud and doesn't respond. Apparently the driver knows how to drive a tractor in a field but we are in a nearly self-driving car.
I have also suggested several times that based on your need for distributing this application across many locations with limited resources and who knows what age of computer, you should consider a web based application. This would allow for instant updates to all users worldwide, You could restrict access if needed. There would be absolutely no cost to any end user unless you wanted to charge a subscription. Images would be available to all users as long as they had a computer, tablet, or phone connected to the internet. No installing anything anywhere.
If you want to continue down the Access path, please consider creating one new thread with the information I suggested in the first sentence above. Also provide what you currently have which I believe is thousands of images.
2023-07-16T21:14:38+00:00
I re-vitalized an old form, with two jpg-files:
For future use, you can even enlarge the pictures using the Zoom+ button:
So, in principle it works, but only with a valid file-specification.
Imb.
2023-07-16T20:19:59+00:00
Me.Image25.Picture = strFile ?????????????
Hi T.Z.,
If strFile contains the full filespecification, including drive and filetype, it should work
Imb.
74 additional answers
  1. ScottGem 68,840 Reputation points Volunteer Moderator
    2023-07-14T12:24:25+00:00
    You do NOT "connect" to it. This has been explained in previous threads. You store the name (and path) to the file in a text field in your table.
    Then you can place an image control on your form or report, bound to that field so you can display the image. If you want to open the image in another appfor better control of the image, you can use code like:
    Application.followHyperlink Me.controlname
  2. Duane Hookom 26,935 Reputation points Volunteer Moderator
    2023-07-14T12:00:48+00:00
    You can't create an ODBC connection to files in a folder. You need to have the file names stored in your table. I believe someone has already provided you with links on how to display images on your form based on the name of the image file.
    Yesterday, I started with a folder of scanned in images of my wife's high school classmates and wanted to create a report of name badges with the images. WIthin about an hour I ran this cmd from the command prompt to create a text file of the images:
    Dir >Images.txt
    I then cleaned up the Images.txt file to remove some top and bottom lines. I could then import the text file and parse out just the image name into a field in my table. I parsed out the First and Last name from the images names which were all similar to Hookom_Duane.jpg. My access file was in the same directory as the images.
    I created a report with some text boxes including the ImageFile field and an image control. I added this code to the On Format event of the Detail section.
    Private Sub Detail_Format(Cancel As Integer, FormatCount As Integer)
        Dim strFile As String
        strFile = CurrentDb.Name   'full name of Access file with the drive and folder
        strFile = Left(strFile, InStrRev(strFile, "\"))   'find just the drive and folder
        strFile = strFile & Me.ImageFile    'add the image file name to the folder
        Me.imgYearbookImage.Picture = strFile    'display the image in the image control
    End Sub
    Done in a couple hours.
