Office Home and Student 2019 for Mac not functioning anymore as of today: Forced to buy a new license??? Unethical!!!
2023-11-20T15:39:33+00:00
As of this morning I have found my legal/registered Microsoft Office Home and Student 2019 (1 Mac) applications (Excel, Word, Powerpoint) do not function properly...
I have searched for similar problems on Microsoft community (found some & then applied all!). Also called "microsoft support" 3 times to look for an answer/solution.
As recommended, after all "Office app removals" (@Apple and Microsoft web sites)+ "license removal tool running" + "Re-installing of Office 2019", they still do not work/function. After the Office package re-install when I try to open an app it says "No license found for my account", although my purchase of Office 2019 can be seen in Microsoft Account (i.e. MS knows that I have legally bought it several years ago)...
Last support center guy told me that "Office 2019 support of MS ended as of Oct'23 -p.s. I confirmed it later-" recommended me "to buy a new license"!... I had bought my license for "LIFETIME". Now, they say "BUY A NEW ONE, just after 3 years!", adding that there is no other address that I can tell about this problem/my complaint (p.s. Live Chat did not work either today)...
Don't want to say bad words to Microsoft after such an ETHICALLY INCORRECT response; so any help of community much appreciated... Thanks.
Biltor Ulucay
Microsoft 365 and Office | Install, redeem, activate | For home | MacOS
Jim G 134.1K Reputation points MVP
2023-11-22T19:06:30+00:00
I think the problem results from AutoUpdate installing a wrong version of Office for your license. You would have to remove the wrong version first:
Uninstall Office for Mac - Microsoft Support
Then, install the correct version, which is 16.78.3 which you can download from this link
Office suite (with Teams)
Please use the Help menu and choose Check for Updates. In AutoUpdate uncheck the box to automatically keep office up to date. 16.78.3 is the final version of Office 2019.
61 additional answers
    2024-03-07T02:45:18+00:00
    I bought the stupid 2021 and now my previous documents won't edit. I can't even copy and create a new document with the old text! Nor can I create a new document on my 'brand new' 2021 office! And this after Microsoft specifically said that buying the 2021 version would fix this! This has to be illegal - fraud at minimum. There is no way I will ever buy 365.
    Does anyone have a solution to this?
    Thanks.
  2. Deleted
  3. Deleted
  4. Deleted
