Migration Tool for Importing Evernote into OneNote
2023-11-29T11:36:17+00:00
Good morning, Microsoft Support Community Team!
 Is there a reputable free tool for migrating my Evernote notes to OneNote?  While I like the Microsoft suite of applications, I had stayed with Evernote due to the sheer volume of notes that I had built up there since 2014.  The free Evernote tier is not as capable nor as free anymore, which is Karma's way of telling me, "Yo, dude, it's time to take the long overdue plunge into OneNote."
 I should have made the migration to OneNote years ago since the [https://www.onenote.com/import-evernote-to-onenote](https://www.onenote.com/import-evernote-to-onenote "www.onenote.com") importer tool has gone 404.
Server Error in '/' Application.
*The resource cannot be found.***Description:**HTTP 404. The resource you are looking for (or one of its dependencies) could have been removed, had its name changed, or is temporarily unavailable.  Please review the following URL and make sure that it is spelled correctly.
Requested URL:/import-evernote-to-onenote).
 I am using a Surface Pro 9 running Windows 11 Home Version 22H2 OS build	22621.2715
 Thank you in advance for your assistance!
2023-11-29T12:39:34+00:00
Greetings! I am Ajibola, eager to assist you with confidence and assertiveness. I guarantee to provide you with exceptional support.
You can follow a step-by-step guide on how to migrate from Evernote to OneNote using Evernote2Onenote. The article explains how to export your Evernote data, install the correct version of OneNote, download and unzip the Evernote2Onenote tool, select your migration preferences, and check your imported notes in OneNote.
'Note: This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.'
https://www.wikihow.com/Migrate-from-Evernote-to-OneNote
If you have any further questions or need additional assistance, please feel free to ask. I'm here to help!
Give back to the Community. Help the next person with this issue by indicating if this reply solved your problem. Click Yes or No below.
Kind regards.
Ajibola.
47 additional answers
    2024-05-08T12:41:41+00:00
    When I right click on a notebook or individual note, it does not bring up an export option.
    Has something changed?
    Thanks!
  2. Deleted
    2024-07-11T04:19:32+00:00
    Thanks for all the work that has gone into this discussion so far- very helpful.
    I apologize- I haven't read all of the above posts, so I may be repeating info.
    You MUST be in the desktop app, not signed in via the web.
    I have successfully installed and run a test on evernote2onenote. HOWEVER.
    The developer's site Evernote2Onenote - Stefans Tools (stefankueng.com) for downloading it has TWO nefarious aspects that I found (maybe there are more?). One is that the links that appear to be for downloading the evernote2onenote app actually downloads and installs a for pay service called DRIVER SUPPORT. Their instructions, if followed, also downloads a file called setup.exe which installs an app called PC App Store. Then once you reboot, you get a fake McAfee popup claiming bogus virus infections. If you try to uninstall PC App Store, their fake message is placed to cover (at least in my case) the approval to uninstall PC App Store. I had to kill PC App store using Task Manager to see and give the approval to remove.
    The only non problematic way I found to download evernote2onenote was to go to the developer's github location (it's in his instructions to install evernote2onenote), download the zip file, and then manually drag it out of the zip file. Yeah, I know that makes no sense, but when I chose extract I couldn't find where it was put.
    This is not a confidence builder.
    Edited 7/20/24 to clarify I am not talking about the wikihow article but the developer's website.
    2024-07-11T10:21:29+00:00
    When I reviewed Evernote2Onenote-1.3.6.zip version 1.3.6 posted to https://github.com/stefankueng/EvImSync/releases on November 30, 2023), I see only Evernote2Onenote.exe, and only the application Evernote2Onenote launches. I am not seeing any of the crapware you mentioned, so I don't know what's going on there. Evernote2Onenote worked just fine for me.
    After being on OneNote successfully for over six months, I was able to recently permanently close my Evernote account since I did not need to get anything from there.
