Migration Tool for Importing Evernote into OneNote
2023-11-29T11:36:17+00:00
Good morning, Microsoft Support Community Team!
 Is there a reputable free tool for migrating my Evernote notes to OneNote?  While I like the Microsoft suite of applications, I had stayed with Evernote due to the sheer volume of notes that I had built up there since 2014.  The free Evernote tier is not as capable nor as free anymore, which is Karma's way of telling me, "Yo, dude, it's time to take the long overdue plunge into OneNote."
 I should have made the migration to OneNote years ago since the [https://www.onenote.com/import-evernote-to-onenote](https://www.onenote.com/import-evernote-to-onenote "www.onenote.com") importer tool has gone 404.
Server Error in '/' Application.
*The resource cannot be found.***Description:**HTTP 404. The resource you are looking for (or one of its dependencies) could have been removed, had its name changed, or is temporarily unavailable.  Please review the following URL and make sure that it is spelled correctly.
Requested URL:/import-evernote-to-onenote).
 I am using a Surface Pro 9 running Windows 11 Home Version 22H2 OS build	22621.2715
 Thank you in advance for your assistance!
2023-11-29T12:39:34+00:00
Greetings! I am Ajibola, eager to assist you with confidence and assertiveness. I guarantee to provide you with exceptional support.
You can follow a step-by-step guide on how to migrate from Evernote to OneNote using Evernote2Onenote. The article explains how to export your Evernote data, install the correct version of OneNote, download and unzip the Evernote2Onenote tool, select your migration preferences, and check your imported notes in OneNote.
'Note: This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.'
https://www.wikihow.com/Migrate-from-Evernote-to-OneNote
If you have any further questions or need additional assistance, please feel free to ask. I'm here to help!
Give back to the Community. Help the next person with this issue by indicating if this reply solved your problem. Click Yes or No below.
Kind regards.
Ajibola.
47 additional answers
  1. Deleted
    2023-12-13T01:11:09+00:00
    question Evernote notebook and select Export just got a message saying I can only export 100 notes at one time I have been with them for over a decade. This will take days transferring batches of notes 100 at a time not to mention confusion organizations, the cost of frustration might be worth staying.
    Feeling trapped
    Help @Ajibola Olanipekun
    2023-12-17T14:43:24+00:00
    Thank you so much - it worked great!
    2023-12-17T15:24:37+00:00
    Interesting - I didn't run into this problem. My only limitation is that I had to export one notebook at a time, which was the long pole in the tent in terms of the overall export process.
    As a test run, I just re-exported my largest notebook, which has multiple thousands of notes (my point being that the number of notes is well over that 100-note limit you encountered). Evernote is exporting all those notes just fine without not giving me that error message.
    After several weeks of using OneNote, I have three (relatively minor) complaints:
    1. The mobile app (at least on the iPhone) is very sluggish when I am typing on a note (at least while I am off of Wifi and out on the 5G network). It has taken some trial-and-error to figure out that I sometimes have to wait up to 5-10 seconds for the cursor to respond to me when I am typing. It looks like the app needs some time to establish the sync connection with the appropriate servers. I haven't had this issue with the desktop version of OneNote while using it on desktop app on WiFi.
    I inadvertently deleted some text because of this issue. Fortunately, the information wasn't critical enough to put me into crisis mode, which led to my second issue.
    1. At least in the free version of OneNote, there is no way to undo an accidental deletion. Evernote had this same limitation.
    2. It took me a few days to figure out how to save and sync my OneNote notes to my personal OneDrive folder so that I can sync OneNote from anywhere.
