Migration Tool for Importing Evernote into OneNote
2023-11-29T11:36:17+00:00
Good morning, Microsoft Support Community Team!
 Is there a reputable free tool for migrating my Evernote notes to OneNote?  While I like the Microsoft suite of applications, I had stayed with Evernote due to the sheer volume of notes that I had built up there since 2014.  The free Evernote tier is not as capable nor as free anymore, which is Karma's way of telling me, "Yo, dude, it's time to take the long overdue plunge into OneNote."
 I should have made the migration to OneNote years ago since the [https://www.onenote.com/import-evernote-to-onenote](https://www.onenote.com/import-evernote-to-onenote "www.onenote.com") importer tool has gone 404.
Server Error in '/' Application.
*The resource cannot be found.***Description:**HTTP 404. The resource you are looking for (or one of its dependencies) could have been removed, had its name changed, or is temporarily unavailable.  Please review the following URL and make sure that it is spelled correctly.
Requested URL:/import-evernote-to-onenote).
 I am using a Surface Pro 9 running Windows 11 Home Version 22H2 OS build	22621.2715
 Thank you in advance for your assistance!
2023-11-29T12:39:34+00:00
Greetings! I am Ajibola, eager to assist you with confidence and assertiveness. I guarantee to provide you with exceptional support.
You can follow a step-by-step guide on how to migrate from Evernote to OneNote using Evernote2Onenote. The article explains how to export your Evernote data, install the correct version of OneNote, download and unzip the Evernote2Onenote tool, select your migration preferences, and check your imported notes in OneNote.
'Note: This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.'
https://www.wikihow.com/Migrate-from-Evernote-to-OneNote
If you have any further questions or need additional assistance, please feel free to ask. I'm here to help!
Give back to the Community. Help the next person with this issue by indicating if this reply solved your problem. Click Yes or No below.
Kind regards.
Ajibola.
47 additional answers
  1. Deleted
    2023-12-10T16:01:42+00:00
    I got the same error message along with a prompt to sign in to OneNote to enable full functionality. I was only subscribed to Microsoft 365 Basic at the time, and when I temporarily upgraded my plan to Microsoft 365 Personal and reattempted the migration it worked. Bit annoying that you have to be on a more expensive subscription for it to work but at least you don't have to buy more than a month's worth of Personal before cancelling again.
    2023-12-10T17:06:05+00:00
    Thanks for the reply. I found my problem - it was that I had the "tags" marked when I created the export file. I was not using tags so I just unchecked that for the export and the import into Onenote worked fine. The only problem that remained is that I had password protected some of the notes in Evernote and the content of the imported note was just misc characters. What I ended up doing for the password protected notes was open them up in Evernote and decrypt them and then copy the content into the note in Onenote. Once you do that then you can put the notes that you want password protected into a separate "section" in Onenote and then password protect that section. The content of all of the notes in that section will be hidden until you enter your password string for that section and then the notes and content will be visible. Apparently you cannot password protect an individual note in Onenote (at least I cannot figure out how to do that if it is possible). If anyone knows how to do that it would be great to find out how.
    Robert Born
    2023-12-10T17:36:50+00:00
    Interesting since I didn't have to upgrade to MS 365 personal in order to do the migration 🤷‍♂️.
    So far, my only gripe with OneNote is that the app is really laggy on my iPhone 13 when I'm out on Verizon's 5G network. It is less laggy at home on WiFi. I have to type slowly since the app is taking its time to fill in the text I just typed. Sometimes the cursor sporadically jumps around a bit. The OneNote responsiveness has been fine on the Surface Pro 9 on home Wifi (I haven't tried it yet off of WiFi).
