Migration Tool for Importing Evernote into OneNote
2023-11-29T11:36:17+00:00
Good morning, Microsoft Support Community Team!
 Is there a reputable free tool for migrating my Evernote notes to OneNote?  While I like the Microsoft suite of applications, I had stayed with Evernote due to the sheer volume of notes that I had built up there since 2014.  The free Evernote tier is not as capable nor as free anymore, which is Karma's way of telling me, "Yo, dude, it's time to take the long overdue plunge into OneNote."
 I should have made the migration to OneNote years ago since the [https://www.onenote.com/import-evernote-to-onenote](https://www.onenote.com/import-evernote-to-onenote "www.onenote.com") importer tool has gone 404.
Server Error in '/' Application.
*The resource cannot be found.***Description:**HTTP 404. The resource you are looking for (or one of its dependencies) could have been removed, had its name changed, or is temporarily unavailable.  Please review the following URL and make sure that it is spelled correctly.
Requested URL:/import-evernote-to-onenote).
 I am using a Surface Pro 9 running Windows 11 Home Version 22H2 OS build	22621.2715
 Thank you in advance for your assistance!
2023-11-29T12:39:34+00:00
Greetings! I am Ajibola, eager to assist you with confidence and assertiveness. I guarantee to provide you with exceptional support.
You can follow a step-by-step guide on how to migrate from Evernote to OneNote using Evernote2Onenote. The article explains how to export your Evernote data, install the correct version of OneNote, download and unzip the Evernote2Onenote tool, select your migration preferences, and check your imported notes in OneNote.
'Note: This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.'
https://www.wikihow.com/Migrate-from-Evernote-to-OneNote
If you have any further questions or need additional assistance, please feel free to ask. I'm here to help!
Give back to the Community. Help the next person with this issue by indicating if this reply solved your problem. Click Yes or No below.
Kind regards.
Ajibola.
47 additional answers
    2024-09-26T17:00:59+00:00
    I am having the following difficulties (using the installed up-to-date version of OneNote from Office 365).
    1. I succeeded in importing notebooks, but OneNote keeps closing.
    2. Some notebooks that have been successfully exported from Evernote do not get successfully turned into OneNote notebooks. (However, the same exported notebooks do travel successfully to Obsidian).
    3. OneNote notebooks that do get created can be opened in the web version of OneNote
    4. All notebooks that I succeeded in importing have now disappeared from the app.
    Obviously, (1) is a nuisance, but (2) and (4) make the migration project non-viable.
    Any advice would be appreciated.
    2024-10-07T21:05:09+00:00
    Good evening.
    I would like to migrated away from Evernote to one note. Can you please guide me through the process on how this can be done in 2024. I am aware that a number of old articles are available but doubt their usefulness. Also, Evernote has gone through a number of changes right after the acquisition by bending spoons.
    2024-10-08T18:48:37+00:00
    Good evening.
    @mark Grech1 You responded to the answer dated in November 2023 but there's a information in this thread that is later, including mine on July 11,2024 which worked, That's not to say there haven't been any changes but that's probably as recent as you will find.. I wish you well.
    Nelson
