Migration Tool for Importing Evernote into OneNote
2023-11-29T11:36:17+00:00
Good morning, Microsoft Support Community Team!
 Is there a reputable free tool for migrating my Evernote notes to OneNote?  While I like the Microsoft suite of applications, I had stayed with Evernote due to the sheer volume of notes that I had built up there since 2014.  The free Evernote tier is not as capable nor as free anymore, which is Karma's way of telling me, "Yo, dude, it's time to take the long overdue plunge into OneNote."
 I should have made the migration to OneNote years ago since the [https://www.onenote.com/import-evernote-to-onenote](https://www.onenote.com/import-evernote-to-onenote "www.onenote.com") importer tool has gone 404.
Server Error in '/' Application.
*The resource cannot be found.***Description:**HTTP 404. The resource you are looking for (or one of its dependencies) could have been removed, had its name changed, or is temporarily unavailable.  Please review the following URL and make sure that it is spelled correctly.
Requested URL:/import-evernote-to-onenote).
 I am using a Surface Pro 9 running Windows 11 Home Version 22H2 OS build	22621.2715
 Thank you in advance for your assistance!
2023-11-29T12:39:34+00:00
Greetings! I am Ajibola, eager to assist you with confidence and assertiveness. I guarantee to provide you with exceptional support.
You can follow a step-by-step guide on how to migrate from Evernote to OneNote using Evernote2Onenote. The article explains how to export your Evernote data, install the correct version of OneNote, download and unzip the Evernote2Onenote tool, select your migration preferences, and check your imported notes in OneNote.
'Note: This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.'
https://www.wikihow.com/Migrate-from-Evernote-to-OneNote
If you have any further questions or need additional assistance, please feel free to ask. I'm here to help!
Give back to the Community. Help the next person with this issue by indicating if this reply solved your problem. Click Yes or No below.
Kind regards.
Ajibola.
47 additional answers
    2023-11-29T17:56:17+00:00
    Ajibola,
     Awesome!  I just ported over my first notebook, so this one is done.
    Thanks!!
    2023-12-05T18:59:14+00:00
    I am trying to do the same, but using a Mac. Is there a version of this utility for migrating from Evernote Mac to OneNote mac version?
    2023-12-05T19:37:15+00:00
    Short answer: NO.
    Bernd
    2023-12-07T12:53:26+00:00
    Hello, short answer is NO it did not work all I got was a bunch of empty pages in the created notebook - NO CONTENT
    following is an error message received for each of the notes.
