Using the find In VBA
2023-02-09T14:01:31+00:00
I am trying to write a macro that will deduct an item from my stock (which is housed in a different workbook) when I hit the complete button. My thoughts were to use the find function, activate the cell, and then subtract the quantity from the active cell. I am just starting with the macro, but I am running into an object error with my find.
Sub Deduct()
Dim C As String
'Deduct the Quantity from Stock
Workbooks.Open "C:\Users\furnd\Desktop\Test Deduct.xlsm"
With Workbooks("Test Deduct.xlsm").Sheets("Sheet1").Range("A1:A2000")
Set C = .Find(What:="A1").Value
End With
Workbooks("Test Deduct.xlsm").Activate
Sheets("Sheet1").Select
C.Offset(0, 1).Select
End Sub
    2023-05-23T18:45:32+00:00
    Jeovany
    It has been a little while since I asked any questions, but I just wanted to say thank you for all the help on this project. I am currently finishing it up. I have been testing it for about the last 2 to 3 weeks and everything seems to be working well. I would not have been able to complete it with out all of the help you provided.
    2023-05-23T19:50:09+00:00
    Hi Tim
    Welcome back!
    I'm glad to know your project is coming to fruition. As for the help, we all have been happy to assist you.
    Do not hesitate to ask more or new questions
    Kind regards
    Jeovany
