Is it possible to have more than one proofing language set in Office products?
2023-01-03T15:56:58+00:00
Or is there quick way to alternate between them? Or at least quick way to disable proofing for current document I'm working on?
I would like to use different proofing languages for different emails I write and I can't find the easy way to do it.
Microsoft 365 and Office | Translator | Other
Stefan Blom 352.1K Reputation points MVP Volunteer Moderator
2023-01-04T13:42:51+00:00
If you click in the paragraph with the Czech text (don't select anything—just leave the insertion point blinking) and then re-visit the Language dialog box, does it correctly state Czech as the text language?
9 additional answers
    2023-01-03T17:44:58+00:00
    Greetings for the day! Thank you for posting here in this forum and I'm an Independent advisor. We are happy to help you.
    Please follow below steps in OneNote to add a proofing language.
    To change the Proofing Language of OneNote 2016, please refer to the link below. https://answers.microsoft.com/en-us/msoffice/forum/all/change-the-proofing-language-for-a-whole-notebook/75de343f-604c-4187-8fa1-ddb2de7193c9
    You may also change the default Proofing Language of OneNote 2016.
    1. Open OneNote 2016.
    2. Click File and go to Options.
    3. Select Language.
    4. Under Choose Editing Languages, select the additional language on Add additional editing languages and click Add.
    5. Select 'New language' and click Set as Default.
    6. Click Yes to continue.
    7. Changes will take effect after restarting OneNote 2016.
    To make sure the language is installed on your computer, follow these steps:
    1. Click the Start button.
    2. Type Language and press Enter.
    3. If the language is not yet added, click Add a language.
    4. Select the language you want to add and click Add.
    After adding the language, please follow the steps in below link to set the default one. https://support.microsoft.com/office/667ba67a-a202-42fd-8596-edc1fa320e00
    Hope this information would be useful to you. Please feel free to get back if you need any additional info.
    Thank you! Ravikumar Help the next person who has this issue by indicating if this reply solved your problem. Click Yes or No below.
