How to stop Excel from automatically checking Workbook performance?
2023-03-06T17:17:06+00:00
Performance check??
The Excel sheet is the way I want it to look and don't want to change it for better performance. I just want Excel to stop prompting me.
Every time I open an Excel sheet, it wants me to do a performance check because of:
"Excess formatting and unneeded metadata cause large, slow workbooks. Check for improvements to performance"
So I find myself X-clicking away this message every time. Because there is no 'excess' of formatting. The Excel sheet simply is a nicely layouted workbook and we want it to be looking this way. We don't need Excel trying to outsmart us and giving this suggestion every time you open the workbook to remove information.
It is only very confusing for not-very-experienced users who also make use of my Excel sheet.
How and where can I set Excel in a way that is stops asking this unwanted question?
  • The question mostly pops-up in the Web version of Office 365.
  • I tried unchecking boxes in the performance check tool, in the desktop version, but to no result.
Would be lovely if someone has a workaround or knows which box needs to be un-checked.
And it would be awesome if a MS engineer helps giving priority to this problem, so that it can be switched of universally.
Andreas Killer 144.1K Reputation points Volunteer Moderator
2025-01-25T10:37:57+00:00
This thread shows that there are a significant number of people complaining about this. Unfortunately, this is only a user forum, we understand your problem, but we cannot do anything to fix it. Only the Excel developers can do this if they are instructed to do so.
As previously stated, this is simply a statistical problem, Microsoft must first recognize that this is a problem. Unfortunately, this is not so easy considering that more than 200,000 people work at Microsoft.
There is a feedback portal where you can cast your vote. There is already a feed on this topic, unfortunately with very few votes. I'm sure if we get as many votes as this post has been viewed, then Microsoft will react.
Anyone reading this, please follow these steps:
Click on this link:
https://feedbackportal.microsoft.com/feedback/idea/89bb523d-b197-ef11-95f6-0022484d7a88
  1. Sign in
  2. Click the Vote button
@HanzieV:
If you mark this reply as answer, it will be the first to appear when someone views this thread. I hope we can encourage as many people as possible to draw Microsoft's attention to this problem. Unfortunately, this is all we can do for you.
Andreas.
155 additional answers
  1. Deleted
    2024-08-30T14:20:36+00:00
    Remove the feature. Nobody asked for it and it doesn't work.
    I don't want you to roll out any AI features for excel. Just a spreadsheet that works. Your devs can work on something else.
    2024-09-02T00:42:41+00:00
    Dear Kelly,
    Thanx for your response Kelly! Btw, could you please confirm this did not work for you in Excel Online or Excel Windows Client build 16.0.17830.20138 (or later)?
    This solution is only available in the Excel Windows Client build 16.0.17830.20138 (or later).
    Sincerely,
    Sukie | Microsoft Community Moderator
    2024-09-02T10:33:57+00:00
    Dear Kelly,
    Sincerely,
    I have version 16.0.17830.20166 and this stupid bar still comes up every time I open a work book - despite hitting the X to close the bar every time.
    Please give us a toggle OFF under advanced options fast.
    Who came up with this absolutely stupid idea - especially without an option to disable? Destroying our workbooks is really not userfriendly.
    Don't touch Excel - we are advanced users and we don't need such thing.
    Didn't you learn from the issue with the app sidebar? Million of people were complaining, because you "forgot" a disable option....
    Or the new work book link? Which is **** too, so we have to research how to get the classic Edit work book links back (via ribbon possible at least).
    If you add features, ok, but leave it to us, if we want to use them or not.
