OneDrive Will Not Run MacOS Catalina 10.15.7
2023-04-04T20:40:32+00:00
I have had Office 365, including OneDrive running on this Mac for several years. Yesterday, OneDrive updated itself (I have the Microsoft AutoUpdater set to automatically download and install updates) to version 23.061.0319. Following that update, it will not run.
I click on the icon in the launchpad, nothing happens
I click on the icon within Finder->Applications, nothing happens
I do not get an error message, there is nothing in the system log, it does not show up in application monitor, it seems to be just dead.
Here is what the system says about the OneDrive.app:
OneDrive:
  Version: 23.061.0319
  Obtained from: Identified Developer
  Last Modified: 4/3/23, 3:18 PM
  Signed by: Developer ID Application: Microsoft Corporation (UBF8T346G9), Developer ID Certification Authority, Apple Root CA
  Kind: 64-bit
If I run Microsoft AutoUpdate, this is what it shows for Microsoft products:
None of the Office products is up to date (Word, Excel, PowerPoint, OneNote, Outlook). They are all on version 16.66 because the next version, 16.71 requires an OS Update, which will never come, because this macbook (Macbook Air, mid 2012) is too old and Catalina 10.15.7 is the most upgraded it can get.
Only OneDrive is up to date, v23061.0319, installed yesterday on 4/3/2023.
What can I do to get back to a previous version of OneDrive so that it works??? This sucks that it did not recognize that the most current version is not compatible with my laptop.
Microsoft 365 and Office | OneDrive | For home | MacOS
    2023-12-19T17:48:08+00:00
    • Sorry, I tried the URL for https://oneclient.sfx.ms/Mac/Installers/23.081.0416.0001/universal/OneDrive.pkg but it fails in the Safari, Chrome, Brave, Duck Duck Go, and Edge browsers. Must be inactive.
    • My version of OneDrive is 23.226.1031 on my MacBook Pro (10.15.7). It does open, I can place files into it, but it does not appear to synch. The "in progress" symbol alongside the file name does not move. I can access OneDrive on my iPhone (iOS 17.2), but what I find in OneDrive are files from more than a week ago which had deleted. Now those week-old can still be opened on the iPhone but are not present on the MacBook.
    2023-12-19T18:03:35+00:00
    Interesting. That is much older than mine. When I go look at the app in the Finder, it has an X over it. They purposely bricked it.
    2023-12-19T18:05:50+00:00
    This solution worked for me. Uninstall previous version and install this one.
    Let's sync and it's up-to-date.
    I downloaded with Firefox.
    Thnx @TRivMoo!
    2023-12-19T18:58:11+00:00
    It will update at some point and break unless you figure out a way to block it.
    2023-12-20T13:22:57+00:00
    In may or jun this year Microsoft fixed the problem after 2 month of silence. But now again, the new version of OneDrive installs automatically and AFTER installation it tells that this version does not work on Catalina. Why does it installs itself before checking the MacOS-version?
    Did they learn nothing by Microsoft about updating the software?
    Installing the old version is only temporary, because the new non-working version installs itself automatically.
    The previous time I could only stop installing OneDrive by installing a special firewall that stops automatically installing software. Unfortunately I forgot the name of that product.
    Maybe somebody remembers
