OneDrive Will Not Run MacOS Catalina 10.15.7
2023-04-04T20:40:32+00:00
I have had Office 365, including OneDrive running on this Mac for several years. Yesterday, OneDrive updated itself (I have the Microsoft AutoUpdater set to automatically download and install updates) to version 23.061.0319. Following that update, it will not run.
I click on the icon in the launchpad, nothing happens
I click on the icon within Finder->Applications, nothing happens
I do not get an error message, there is nothing in the system log, it does not show up in application monitor, it seems to be just dead.
Here is what the system says about the OneDrive.app:
OneDrive:
  Version: 23.061.0319
  Obtained from: Identified Developer
  Last Modified: 4/3/23, 3:18 PM
  Signed by: Developer ID Application: Microsoft Corporation (UBF8T346G9), Developer ID Certification Authority, Apple Root CA
  Kind: 64-bit
If I run Microsoft AutoUpdate, this is what it shows for Microsoft products:
None of the Office products is up to date (Word, Excel, PowerPoint, OneNote, Outlook). They are all on version 16.66 because the next version, 16.71 requires an OS Update, which will never come, because this macbook (Macbook Air, mid 2012) is too old and Catalina 10.15.7 is the most upgraded it can get.
Only OneDrive is up to date, v23061.0319, installed yesterday on 4/3/2023.
What can I do to get back to a previous version of OneDrive so that it works??? This sucks that it did not recognize that the most current version is not compatible with my laptop.
Microsoft 365 and Office | OneDrive | For home | MacOS
    2023-04-24T10:35:45+00:00
    My idea is to find and prevent updater daemons from running.
    Isolate the iMac from the Internet and after having installed a correct version of OneDrive, start Finder and go to the application folder, then locate the OneDrive app, then right click and select "show the package content". It opens a new folder.
    From here, right click on StandaloneUpdaterDaemon.xpc to open a new folder again. I located the executable file in the Contents\MacOS directory. To prevent it from running, I then started a terminal at that directory and at the command prompt, I ran the command sudo chmod -x ./StandaloneUpdaterDaemon
    The ls -l command shows the execution rights are removed:
    Next I did the same procedure as above for OneDriveUpdaterDeamon.xpc
    2023-04-24T17:16:56+00:00
    Hi All, The key is to prevent the auto-update to run, keeping the version that is compatible with Catalina.
    See this video on Youtube https://youtu.be/mP_bdrlnjw4
    2023-04-24T23:52:20+00:00
    RUNNING MAC OS CATALINA, I'VE TRIED EVERYTHING MENTIONED IN THIS THREAD AND THIS IS THE ONLY THING THAT HAS WORKED.
    THANK YOU. :)
    2023-04-25T16:23:31+00:00
    I have a fairly homemade solution but it worked for me.
    1- Uninstall the app, move the application app to the trash.
    2- Install version 23.002.0102.0004.
    3- Open the activity monitor and filter by the Update process
    4- When the app starts, a OneDrive Update process appears, close it forcefully. I think it appears twice, close it.
    Then login to the app, it shouldn't close.
    The key is to kill the upgrade process that is running in the background and close it. This at least the first time.
    To prevent that Update process from running again, I did the following:
    Navigate to the Applications folder on your Mac and find the OneDrive application.
    Right-click on the OneDrive application and select "Show Package Contents."
    From there, go to the Contents
    Find the Ondrive Update process, add your user as the owner of the process and set it as "blocked". Also remove system permissions on said executable.
    Also in the app settings, disable the application from opening when I log in, so at least until Microsoft resolves the error, I will open the app along with the activity monitor open and make sure that the update process does not run .
    I hope it works for you.
    Greetings!
    Why not simply delete the Ondrive Updater?
    2023-04-28T11:13:13+00:00
    me too. Only thing that has worked. Thanks Aaron.
