A Microsoft file hosting and synchronization service.
please send me the complete command strings to do this....
I have had Office 365, including OneDrive running on this Mac for several years. Yesterday, OneDrive updated itself (I have the Microsoft AutoUpdater set to automatically download and install updates) to version 23.061.0319. Following that update, it will not run.
I click on the icon in the launchpad, nothing happens
I click on the icon within Finder->Applications, nothing happens
I do not get an error message, there is nothing in the system log, it does not show up in application monitor, it seems to be just dead.
Here is what the system says about the OneDrive.app:
OneDrive:
Version: 23.061.0319
Obtained from: Identified Developer
Last Modified: 4/3/23, 3:18 PM
Signed by: Developer ID Application: Microsoft Corporation (UBF8T346G9), Developer ID Certification Authority, Apple Root CA
Kind: 64-bit
If I run Microsoft AutoUpdate, this is what it shows for Microsoft products:
None of the Office products is up to date (Word, Excel, PowerPoint, OneNote, Outlook). They are all on version 16.66 because the next version, 16.71 requires an OS Update, which will never come, because this macbook (Macbook Air, mid 2012) is too old and Catalina 10.15.7 is the most upgraded it can get.
Only OneDrive is up to date, v23061.0319, installed yesterday on 4/3/2023.
What can I do to get back to a previous version of OneDrive so that it works??? This sucks that it did not recognize that the most current version is not compatible with my laptop.
This link to get older version of OneDrive doesn't exist
please help to get an older version of one drive
Try this:
OneDrive build 23.081.0416.001 contains the fix for the Catalina launch issue. It's currently available on the Insiders ring, and is due to reach 100% production on 5/3.
In the meantime, you can grab it from https://oneclient.sfx.ms/Mac/Installers/23.081.0416.0001/universal/OneDrive.pkg
Hi Aaron, thank you!!
This version has solved on Catalina and now OD starts and works fine.
