OneDrive Will Not Run MacOS Catalina 10.15.7
2023-04-04T20:40:32+00:00
I have had Office 365, including OneDrive running on this Mac for several years. Yesterday, OneDrive updated itself (I have the Microsoft AutoUpdater set to automatically download and install updates) to version 23.061.0319. Following that update, it will not run.
I click on the icon in the launchpad, nothing happens
I click on the icon within Finder->Applications, nothing happens
I do not get an error message, there is nothing in the system log, it does not show up in application monitor, it seems to be just dead.
Here is what the system says about the OneDrive.app:
OneDrive:
  Version: 23.061.0319
  Obtained from: Identified Developer
  Last Modified: 4/3/23, 3:18 PM
  Signed by: Developer ID Application: Microsoft Corporation (UBF8T346G9), Developer ID Certification Authority, Apple Root CA
  Kind: 64-bit
If I run Microsoft AutoUpdate, this is what it shows for Microsoft products:
None of the Office products is up to date (Word, Excel, PowerPoint, OneNote, Outlook). They are all on version 16.66 because the next version, 16.71 requires an OS Update, which will never come, because this macbook (Macbook Air, mid 2012) is too old and Catalina 10.15.7 is the most upgraded it can get.
Only OneDrive is up to date, v23061.0319, installed yesterday on 4/3/2023.
What can I do to get back to a previous version of OneDrive so that it works??? This sucks that it did not recognize that the most current version is not compatible with my laptop.
Microsoft 365 and Office | OneDrive | For home | MacOS
    2023-04-18T07:57:26+00:00
    Tuesday April 18,2023
    As per above I too have noticed the problem last week on my iMac. OneDrive was not running and won't open on your iMac 10.15.7.
    I uninstalled OneDrive App, restarted iMac, Download OneDrive App. Installed, restarted iMac and OneDrive App still will not open.
    Thanks Fred
    2023-04-18T11:27:59+00:00
    Hallo Catalina-Fans
    today i installed onedrive app from january 2023 :: it is okay
    i found it on this site:
    https://hansbrender.com/all-onedrive-versions/#tabmac
    (many thanks to this spezialist ....)
    for stopping automatically updates
    i deleted all apps and files found in the onedrive.app package named similar to"onedriveupdater...."
    so you will find entrys like:
    onedrive has currently to execute over 220.000 (!) changes bcause :
    all my cloud content ( 700GB ) has to been downloaded to my big disk ...
    2023-04-18T17:15:41+00:00
    UUPS after deleting the update elements onedrive cannot be restarted !
    so i installed onedrive again
    and renamed the update procedures AFTER starting onedrive !
    for a restart i renamed the special elements back as shown below
    and it began to work
    to prevent hidden updates i renamed the update.... elements again
    starting onedrive (not automatically at startup) should be done by a script
    who could create this for me ?
    2023-04-19T06:56:15+00:00
    @JohannesLang1
    Finally, I changed the access rights ont that files whith chmod -x command in a terminal, I did not rename or remove files. I restarted several times and the update process won't work anymore.
    2023-04-19T08:39:22+00:00
    thanks for this tipp
    i will try it tomorow
