A Microsoft file hosting and synchronization service.
I have very disappointed that MS had not completed testing before it put the app update in the public. And it causes the app issue and the system issue also.
I have had Office 365, including OneDrive running on this Mac for several years. Yesterday, OneDrive updated itself (I have the Microsoft AutoUpdater set to automatically download and install updates) to version 23.061.0319. Following that update, it will not run.
I click on the icon in the launchpad, nothing happens
I click on the icon within Finder->Applications, nothing happens
I do not get an error message, there is nothing in the system log, it does not show up in application monitor, it seems to be just dead.
Here is what the system says about the OneDrive.app:
OneDrive:
Version: 23.061.0319
Obtained from: Identified Developer
Last Modified: 4/3/23, 3:18 PM
Signed by: Developer ID Application: Microsoft Corporation (UBF8T346G9), Developer ID Certification Authority, Apple Root CA
Kind: 64-bit
If I run Microsoft AutoUpdate, this is what it shows for Microsoft products:
None of the Office products is up to date (Word, Excel, PowerPoint, OneNote, Outlook). They are all on version 16.66 because the next version, 16.71 requires an OS Update, which will never come, because this macbook (Macbook Air, mid 2012) is too old and Catalina 10.15.7 is the most upgraded it can get.
Only OneDrive is up to date, v23061.0319, installed yesterday on 4/3/2023.
What can I do to get back to a previous version of OneDrive so that it works??? This sucks that it did not recognize that the most current version is not compatible with my laptop.
I also cannot get OneDrive version 23.061.0319 to launch on my MacBook running Catalina 10.15.7. It works OK on my iPhone and iPad.
I have tried everything in this thread, reinstalled the OneDrive app multiple times, and am about ready to pull my hair out.
Things synch on the onedrive.live.com website, the iPhone, and the iPad. But OneDrive refuses to work on my MacBook. All this seems to have started on April 6..
THIS WORKED.
I replaced 23.061.0319 with 23.054.0313.0003.
Now . . . how do I prevent this from happening all over again???
mine still not
Don't know what to do
The reinstall whole macOS is the last thing to do :(
replaced with 23.054.0313.0003 but still did not work.
Initially the Onedrive cloud appeared on the top, asked for login id and password and they it just disappeared and stop functioning.
Not visible in activity monitor as well.
