Text disappearing and reappearing while typing MS word
2022-10-18T02:21:04+00:00
Hey All,
Running windows 11. ASUS m16.
Today a very weird quirk in word cropped up. As I'm typing, words that I've just typed will have random letters disappear and then reappear. When I delete something, sometimes the thing I just deleted will reappear on the document only to disappear when I'm typing elsewhere. No lag or anything happening, just randomly disappearing characters and reluctantly deleted words. Any idea if this is an issue related to a recent patch?
Cheers,
Nate
Microsoft 365 and Office | Word | For education | Windows
2023-05-10T09:01:09+00:00
Enabling typing suggestions as suggested by MH524 on 23rd Feb 2023 seems to reduce, but not fully fix the issue for me. However, the suggestion popups are VERY distracting! Perhaps the suggestions popup causes a refresh of the image which clears the missing characters.
HOWEVER, I THINK I FOUND A FIX, based on this idea of "refreshing".
I found an article on techpowerup entitled "Graphical glitch in Word and Outlook (Office 365)".
I don't have GeForce Experience installed, but I do have Nvidia control panel, so I did the following things (I'm not sure that all of them are needed), but this is now fixed and working for me:
  1. In Nvidia control panel, I added Word and Outlook as separate programs to my "Manage 3D settings" under the "Program Settings" tab and for both I set the following:
  2. "Low latency mode" = Ultra.
  3. "power management mode = Nvidia recommended
  4. "preferred refresh rate = highest available.
  5. "vertical sync" = on
I restarted Word and Outlook and the disappearing characters are gone!
98 additional answers
    2023-04-30T23:02:11+00:00
    I'm on Windows 11 Pro and don't have dwm.exe or Desktop Window Manager service.
    Have you looked in the Details tab in the left vertical column of Task Manager?
    2023-04-30T23:12:04+00:00
    You're right, it was there. When I end the task, the screen goes black for a moment and comes back. dwm.exe comes back as well.
    I think it's the desktop and icons manager, and cannot be disabled.
    2023-05-01T17:29:01+00:00
    Thanks for trying out. But does the Word text issue go away despite dwm.exe coming back after killing it?
    It does not in my case.
    2023-05-01T19:12:39+00:00
    Has anyone install AMD's 23.4.3 driver to see if it resolves the issue?
