Excel Stocks not working in Office 365 after installing macOS Ventura v13.0
2022-10-25T17:56:07+00:00
**Parameters:**Hardware: Mac mini 3.6 GHz Quad-Core Intel Core i3
Software: Office 365 (v16.66.1)
OS: macOS Ventura (v13.0)
Connected Experiences: All On
Auto Update: Have always been On for both Office 365 and macOS
Additional: Nothing new has been installed on the system for over a year (other than SW updates)
TimeLine:
Two days ago: Microsoft Auto Update hung for hours
- Reinstalled MS Auto Update and was able to update MS apps
- Excel Stocks working fine yesterday
This morning: Received error message: "COULDN'T REFRESH DATA TYPES We need to fix your account. Select Microsoft Excel from the top menu > Sign Out. Then sign back in with the account associated with a subscription."
Steps Taken:
Signed out of Office 365; signed back in. No change, and "Stocks" is missing.
Hard Reboot: No change, and "Stocks" is missing.
Scoured the forums online...pretty much tried everything that I could find...
Removed Office 365 Apps, reinstalled, rebooted, etc., signed in again, verified Connected Experiences all are on, and "Stocks" shows up as a menu item: however, when clicking on it, the same error message appears ('COULDN'T REFRESH DATA...").
Removed Office 365 another two times, reinstalled, rebooted, verified Connected Experiences, etc. etc. and no change.
Nothing has changed with my Office 365 subscription (still active, valid, no additional users, etc.).
Thoughts/Questions:
Is this a problem with the latest version of Office 365 (v16.66.1)?
- If so, is there a way to roll back to an earlier version that we know works (I have researched and not been able to find out how to do this.
Is this a problem with the latest version of macOS (Ventura v13.0)?
- If so, is there a way to roll back to a previous version of macOS?
If this isn't the right forum to solve this issue, can someone point me to where I can get assistance; I'm happy to pay a fee, as I'm over four hours of spinning my wheels with everything I've tried.
Thanks in advance to anyone who can assist.
Microsoft 365 and Office | Excel | For home | MacOS
2023-01-26T18:59:10+00:00
I just received this from Microsoft:
Thank you for sending Microsoft feedback. Your input is valuable to us and helps improve our products.
Your feedback directly resulted in improvements to Office and we believe your issue has been addressed in the latest version of Office 365. Thank you! To get the latest update, follow the steps here.
For your reference, you submitted the following feedback on November 3, 2022:  MacOS Ventura 13.0 users have to downgrade to Version 16.65 because all newer versions up to beta 16.68 do not support stock quotes anymore! See this community report: https://answers.microsoft.com/en-us/msoffice/forum/all/excel-stocks-not-working-in-office-365-after/392964ae-24de-43c2-af1e-07aa33659a61
If you have any questions, please reply back to this email.
Thank you,
The Microsoft Office Team
Note: Bold & Underline above was added by me
135 additional answers
    2022-10-25T20:00:25+00:00
    Figured out the Problem...now just have to find a solution:
    Problem: There's some sort of incompatibility with Ace Ventura and Excel Stocks. How I know this...I'm running Excel Stocks (v16.66.1--same as above) and macOS Monterey (v12.6) on a MacBook Pro 2017, and Excel Stocks works fine. Looks like I will now have to wait for either MS or Apple to fix it, as moving back to the Monterey OS is, well...not very easy. It apparently makes the hour-long process to install Ventura seem like child's play. Shaking my head.
    Suggestion to Others: Don't upgrade to macOS Ventura (v13.0) if you want Excel Stocks to work, and turn off your friendly auto-update feature.
    2022-10-26T12:58:05+00:00
    Update Apple: Only solution after communicating with Apple would be to roll back to Monterey OS...there's a risk of losing data and the process isn't straightforward.
    Update Microsoft: The issue is starting to become known (as expected as people upgrade). It has been forwarded to the technical/engineering team. We will need to wait for either a work-around or an update to v16.66.1.
  3. Jim G 134K Reputation points MVP
    2022-10-26T16:31:30+00:00
    You might try reverting to the previous build of Excel using Time Machine to restore Microsoft Excel.app in the Applications Folder.
    Learn how to use Time Machine to restore specific files
    2022-10-26T17:00:57+00:00
    I very much appreciate the idea. On the surface, it doesn't appear to be very simple, and my concern would be that after the effort, it doesn't work. So, I think if I revert to a former build, I'd probably go Ventura > Monterey, as I know that Monterey works with the Excel App. That said, it appears these would be the steps to go to a previous Excel build (for those that want to try it). If anyone does try, it would be great if they shared the results.
    https://support.microsoft.com/en-us/topic/how-to-revert-to-an-earlier-version-of-office-2bd5c457-a917-d57e-35a1-f709e3dda841
