A family of Microsoft relational database management systems designed for ease of use.
Ok. Some new information in my case. (Stull using "working" 16.0.14701.20262)
At first apperience have we made it to work by using UNC connected directly to fileserver share.
Application file is linked to Backend database file with UNC paths to share.
The applications file (which is also on fileserver in our case) must also be opened from UNC (so mapped letter in file explorer does not work).
This could be a work around until update is coming, but...
Unfortunatly did I discover that even if running with UNC directly to shares doesn't "pessmistic row record locking" work. It uses optmistisk locking. Doesn't matter if set in Offfice settings, in every Form och using VBA Application.SetOption "Use Row Level Locking", True.
You could argue against pessmistic locking, but our users has that as a requirement. The main/first reason that we have Access as back end instead of SQL server.
So work around does not work and since this is the case do I fear that we have higher chance of getting uglier locking/data update problems which might cause more severe errors like corrupt database file etc.
So be warned if you are trying the "UNC to direct shares" work around. It might have/cause none obvious faults.
Regards,
Sven
