"Could not lock file" with Access build 14701.20248
2021-12-14T19:16:08+00:00
I had a client today who could not open their shared backend database. The system displayed the error “Could not lock file”.
I determined that Access was trying to open the file in exclusive mode, even though none of the normal methods to open the file exclusively were being applied:
• The File / Options / Client Settings / Advanced / Default open mode was set to Shared
• No command line /excl  was being used
• The user had Full Control permissions for the shared folder containing the database
• Creating a new test database opened it exclusively, so that no other user could open it.
• The newly created test database could not be reopened if another user opened it,
• Several other users could simultaneously open the new test database without a problem.
The user had been using the database for normal operations for several days prior to the problem.
The user’s system has updated to build 16.0.14701.20248 today.
All other test users had build 16.0.14701.20226.
I rolled the user's Office installation back to 16.0.14701.20226 by using the Office Deployment Tool https://support.microsoft.com/en-us/topic/how-to-revert-to-an-earlier-version-of-office-2bd5c457-a917-d57e-35a1-f709e3dda841
The problem was solved.
Can anyone else confirm that this problem exists with the latest build of Access?
Neil Sargent
Smart IT Ltd
Microsoft 365 and Office | Access | For business | Windows
    2021-12-21T08:52:36+00:00
    Hello Shane,
    I can confirm this behavoir on two freshly installed systems. I've applied the semiAnnual-Channel. On Installation, it was version 13801.21050. I've upgraded to 13801.21092 on both systems. I've also checked the Versions of acecore.dll 16.0.13801.21092 (modification date: 2021-12-21 09:08, size 1,69MB) Even after a reboot the system persists.
    Some thing that I've noticed: In some cases, the Lock-Files are not removed after closing the database and they are all empty (0 Bytes)
    If you need further information about our environment, send me a notice.
    regards, Philipp
    2021-12-21T09:06:18+00:00
    I can also confirm that lock-files remains with 0 bytes size after closing Access.
    We have 16.0.14701.20262 though.
    // Sven
    2021-12-21T09:06:40+00:00
    hi, we work with front/back access application where the back end is on a shared drive.
    Problem is not solved. Updated to the latest version. acecore.dll is 16.0.14701.20262
    2021-12-21T09:08:29+00:00
    I would like to get a little more information outside the public form to see if I can help.
    To do that, can you post some feedback using send-a-frown in Access, with your issue, and the keyword "lockfileissue". Make sure to check the box to include your email address when you submit the feedback.
    I'll respond to that feedback directly.
    2021-12-21T09:12:33+00:00
    Can you determine if you are using 8.3 names for file names or directory paths?
    Are there any symlinks, juntions, or hard links involved in the path to your database?
    If you delete the .laccdb file before opening the database, does the .laccdb file get created when the first user opens it?
