Access version 2201 problem with laccdb
2022-01-31T10:47:34+00:00
Hi!
I have a problem when closing Access program since Access version 2201 (26th January 2022).
There is still a "record-locking informations" laccdb not closing (and that results in several other errors as well like accdb is not opening again and others.
I had to go back to version 2112 ... and then all is fine again.
Is this a wellknown problem with version 2201 already? .... and will this be fixed in a next version?
Thanks for answers
G.
Microsoft 365 and Office | Access | For business | Windows
2022-02-03T13:08:26+00:00
Most valuable professional. It just means MS recognizes that an individual as contributing to the community. Basically, I help in forums a lot, answer lots of questions, have a very extensive website with lots of information... try to help other users freely. I do not work for MS! I am not paid by MS! I simply try to help fellow users when I can.
49 additional answers
    2022-02-02T22:58:04+00:00
    I had already posted my follow up question before seeing your reply. Thanks so much I'll check out that link and give it a try.
    2022-02-02T23:09:57+00:00
    Here is a list of Office 2021 built numbers (both volume license and retail versions): https://docs.microsoft.com/en-us/officeupdates/update-history-office-2021
    I was not sure if the target number in the XML should also begin with 16.0.xxxx.xxxxx, but according to Wikipedia, this is the case: https://en.wikipedia.org/wiki/Microsoft_Office_2021
    Best regards
    Sascha Debie
    2022-02-02T23:17:41+00:00
    Any idea how to find out what the version code is for various versions. I'm currently trying to revert this:
    Version 2112 (Build 14729.20260)
    and the format I need is:
    <Updates Enabled="TRUE" TargetVersion="16.0.14701.20226" />
    I'm wondering if this would be it:
    <Updates Enabled="TRUE" TargetVersion="2112.14729.20260 />
    2022-02-02T23:21:36+00:00
    Okay, I think I found it.
    2016
    2019
    2021
    Office365
    all use 16.0 as the version. Then it's just the build number. So:
    16.0.14729.20260
    I'll go try that.
