A family of Microsoft relational database management systems designed for ease of use.
So, it looks like my organization upgraded to the following over the weekend:
Version 2108, Build 14326.20702 Semi-Annual Enterprise Channel (Preview)
Before, it was just the Semi-Annual Enterprise Channel. Not sure why the change to Preview and what it means. Looking at that chart on this page, it looks like that is one of the fixes for the Preview Channel, but not the full fix.
However, I've tested Access this morning and this seems to have fixed the problem! It allows multiple users and locking file acts normally.
Maybe they'll eventually upgrade to the build with the full fix (14326.20738), but either way, Version 2108 seems to work.
Shane ... is it safe to stick to this build since it seems to work? Or should I ask my IT department to move to build 20738 ?
