A family of Microsoft relational database management systems designed for ease of use.
Thank you Shane! I'll be talking to our IT department today.
On 12/14/2021, SemiAnnual Enterprise channel updated to version 16.0.13801.21086. This is causing several strange behaviors in Microsoft Access. For example:
Reverting to the prior version 16.0.13801.21050 fixes the problem.
This problem seems specific to databases located on a network share. For databases on a local machine, there is no issue.
If you are on version 2201, that means you are on Current Channel (Preview), rather than Current Channel.
However, build 14827.20088 should have the full fix, so if you are still encountering problems, it is likely because there is still some user with an older build.
The most recent Current Channel (Preview) build is 14827.20122.
Shane Groff
Once the file is locked is there a shortcut or hotkey we can use to open the file to unlock it or do we just need to do a restore on the locked file
Hi Edward,
I don't think I understand your question. The file is locked when it is opened by a version of Access with the problem. When you close the database, it will be unlocked.
Shane
When it is stored on a shared network it does not clear after the user close it out. It is staying locked
