Lock File Problems with Access 16.0.13801.21086
2021-12-14T12:18:17+00:00
On 12/14/2021, SemiAnnual Enterprise channel updated to version 16.0.13801.21086. This is causing several strange behaviors in Microsoft Access. For example:
  1. Create a new Access database on a network drive or open an existing database from a network drive. Close it. The .laccdb file is not automatically deleted (even though no other users are in it).
  2. Use DAO to OpenDatabase for shared (non-exclusive) access. Error 3050 (“Could not lock file.”) is thrown and the database is not opened.
  3. Databases opened on a network drive appear to always be opened for exclusive access. Once one person has opened a database, others can't--even when opening for shared access.
Reverting to the prior version 16.0.13801.21050 fixes the problem.
This problem seems specific to databases located on a network share. For databases on a local machine, there is no issue.
Microsoft 365 and Office | Access | For business | Windows
    2021-12-15T11:21:29+00:00
    We have found the culprit for our problem!
    My team have found that the problem was in security update for MS office 2016 (KB5002099)
    After uninstall problem is solved
    2021-12-14T18:36:30+00:00
    I reported it to Microsoft earlier this morning, waiting to hear back.
    Use the application feedback command within Access to send in your comments to the Dev Team.
    I now see another similar thread in this forum with similar symptoms
    https://answers.microsoft.com/en-us/msoffice/forum/all/this-file-is-in-use-error-received-with-build/4a406c85-6d06-4601-905c-12aa9930d343
  3. Deleted
