Lost all animation when converting PowerPoint to video
2020-12-27T21:19:28+00:00
Hi
I can't seem to find this answer anywhere on the Web. I created a PowerPoint presentation with animations, recordings and transitions between slide. As usual I would save this as a open document on my one drive or desktop. I then exported this PowerPoint into a full HD video. Previously it would work perfectly. Today when I converted it into a video all my animations, transitions and sound editing were deleted. So when I played the video it was slides and audio but no animations or effects. When I went back to PowerPoint all my animations had disappeared from the animation pane. This was the case for all my power points. I decides to re animate 15 slides and try the process again. I saved a copy on USB. When I converted desktop version to video app animation was lost. I plugged USB and opened up PowerPoint and animation was lost.
I have tried to restore previous copies of my powerpoint but none of them have a copy of my animation. I'm confused as it means I can no longer create my educational PowerPoints.
Please can someone help
Thank you!!!
    2021-04-04T17:27:59+00:00
    Thanks for standing by on this concern. Just want to update this thread that we’re still waiting for the advice of our Internal Support as this concern is still under investigation.
    Regards.
    2021-04-11T18:44:41+00:00
    We’re still waiting for the update of our Internal Support. We’ve sent a follow-up message to confirm its status. We’ll let you know once we receive any response from them.
    Regards.
    2021-04-18T17:50:39+00:00
    We appreciate you for standing by on this concern. As we’ve checked this concern, we haven’t received any updates yet from our Internal Support. We’re making sure to monitor this on our end and we’ll get back to the soonest time possible.
    Regards.
    2021-04-25T17:45:54+00:00
    Thanks for waiting. At the moment, they are already coordinating to the Product Group to check the status of this concern that was raised. We’ll let you know if there are other updates about this.
    Thank you.
    Louie Del
  5. Deleted
