Enable multiplayer mode for minecraft java (Microsoft account)
2020-12-26T16:10:18+00:00
Hi!
I have just bought minecraft for my daughter. Windows 10 - Java edition.
We cant understand how to enable the multiplayer option.
It says check settings for the microsoft account, but we cant find where to do this when logging into either my (family account) or her microsoft account.
We really need help here.
Regards
Johan
Microsoft 365 and Office | Microsoft Family Safety | For home | Windows
2020-12-26T16:57:14+00:00
Hi JohanKvissberg,
I am John, an Independent Advisor and a Microsoft user like you. I'm here to work with you on this issue.
To manage the settings you need XBox Family Settings app.
  1. Sign in to the app with an organizer’s Microsoft account, and then do one of the following to get to Settings:
-Select the tile for the member you want to manage, and then select the Settings icon in the top-right corner of the Family screen.
-Select the Settings icon at the bottom of the Family screen, and then select the tile for the member you want to manage.
  1. Select the Multiplayer tile and turn Allow off or on.
Source (answer provided from JonasBernotas): https://answers.microsoft.com/en-us/windows/for...
I hope it worked out well for you. If not, please reply back to this forum to let me know. I will be glad to follow up and help you.
Regards,
John
600+ people found this answer helpful.
116 additional answers
    2020-12-27T18:41:54+00:00
    Clutch John!
    I had the identical problem and your steps resolved it.  Thanks.
    Mike
    2020-12-27T20:08:24+00:00
    I'm having the same problem, and I found those directions, but I still can't figure it out.  Is an XBox Family account different form a Microsoft Family account?
    2021-01-02T00:26:46+00:00
    Thanks for this.. i found the switch and submit but it doesnt stick.  Goes back to block.  I'm insanely frustrated.  Please help.  Thanks
    2021-01-07T21:23:48+00:00
    My friend is having the same issue but with a regular microsoft account
