OneNote Bengali Language problem
2020-10-04T03:43:14+00:00
In Microsoft One Note apps, the letters in Bengali language come separately, the letters come before and after.
    2020-11-10T19:27:19+00:00
    Bengali writting works fine on word sheet, Sticky note. But on note sheet and excel sheet, words are broken.
    You can use same algorithm as sticky note on Note sheet editing.
    Build no (one note):
    16.0.13231.20222
    Please have a look in the screenshots I have attached.
    2020-11-13T18:31:44+00:00
    1. While writing Bangla, try using "Nirmala U I" font. it may solve your font breaking problem.
    2. If you want to fix the fonts that have already broken, copy them to MS Word, and change the font to "Nirmala UI" and again past on the OneNote.
    I have fixed this problem of font breaking this way.
    hope you will be benifited.
    2020-11-13T19:00:00+00:00
    Thank you for your solution. This will be helpfull for PC I think. But unfortunately my problem is in android device. Is there any solution regarding bangla typing in android phone?
    2020-12-15T10:15:20+00:00
    Hello Jazlyn,
    I would like to inform you that, I am using Avro keyboard in my Windows 10
    However, I am having this Bengali word breaking problem only in one note, not in other office applications.
    Copy, paste or Avro on- screen keyboard layout, nothing is actually working.
    And, as I have gone through the other answers, I think, the problem is not with keyboard.
    Take a look at the screen shot -
    As you can see, the problem still persists even after pasting from word, and the font is always in Nirmala UI. I would like to add,is copying and pasting from other source the actual solution?
    Looking forward to your co-operation.
    Thanks and Regards from Bangladesh.
    2020-12-15T13:49:31+00:00
    Well said👍
