How to hide "Click a person to see what they’re working on"
2020-09-14T17:59:25+00:00
Hi  ,
I dont want to show the details of contacts whom with I work closely , Is there any option in Delve using which we can hide the option "Click a person to see what they’re working on" so that I can disable it and it will no longer visible to all in organisation.
Thanks in advance !!
Microsoft 365 and Office | Microsoft Viva | Viva Insights
2020-09-16T09:25:15+00:00
Hi Sachin,
We appreciate that you posted back and provided your feedback here.
Per your description, it seems that you also want to hide the name of people under “Click a person to see what they’re working on” section, and you don’t want the others see whom you frequently contacted.
If so, we have also searched a lot and we cannot find a setting to hide the name of people under this option.
Given this situation, we understand that you want to find such settings. On the one hand, as we mentioned above, you can go to Delve UserVoice to provide your feedback. Microsoft will keep monitoring customers feedback there, some features would be added to the products and services based on customers feedback in the future, and your good ideas will be very helpful for the dedicated engineers in Microsoft to improve the services.
On the other hand, we found that if you go to Delve Settings > Feature settings > turn off Documents feature, in this situation, if you turn off it, others will still be able to find your documents in Office 365 if they have access to them. They just won’t show up in Delve or in the Discover view in OneDrive for Business.
At the same time, it will turn off Get back to your recent documents and email attachments, Click a person to see what they’re working on, Discover documents from people around you features at the same time, as shown below:
Thank you for your understanding and patience.
Best Regards,
Sukie
3 additional answers
    2020-09-15T02:54:31+00:00
    Hi Sachin,
    Thank you for querying in this forum.
    According to your description, it seems that you want to disable “Click a person to see what they’re working on” this feature in Delve.
    If my understanding is right, we’re afraid that there is out of box way to disable this feature in Delve separately. We have also searched a lot and test it on our side, and we cannot find a way to turn off it.
    We’re sorry that it doesn’t meet your requirement. I do understand the inconvenience caused and apologize for it.
    To address your concern, we’d suggest you go to Delve UserVoice to provide your feedback. his is the best platform to let us hear from you and make our products and services better for you and others.
    Your understanding and patience will be highly appreciated.
    Best Regards,
    Sukie
    2020-09-15T10:54:43+00:00
    Hello Sukie ,
    Thank you very much for your response
    Can I hide the people name available under this option as I dont want to show everyone that to whom I frequently contacting, When people search my name on delve I dont want then to view the list of contact whom I frequently contact
    2020-09-16T17:46:09+00:00
    Thank you very much for all  your help here
