Create a seat assigner with Excel and RFID
2020-04-16T23:26:27+00:00
Due to Covid19, we are tracking who sits with who in the cafeteria.
We have a simple Excel file that assigns a seat in the cafeteria to the employees based on the RFID. It is very simple, We have a Seat column with seats from 1-135, they scan their badge, the ID number appears on the ID column, then there is a name column with a Vlookup based on the ID that enters the name of the employee and that is it.
The issue we have is that, sometimes it assigns a seat that is still taken. I cannot think of a way in which the employee scans their badge again and the record is deleted from the seat number so that it is now free for someone else :S and doing that without losing the original records of where the person sat.
Any ideas would be highly appreciatted
2020-04-23T05:33:48+00:00
@ Debbie.
I have no scanners here, so I typed in the ID numbers
1- Before the start
The SCAN sheet will look like this, The scanner will be focused on cell C3 Named range ScanID
2- After the first 10 scan (employees)
After the first 10 scan (employees) on each sheet
RECORD/TRACKING before any check-out.
3- After some of the staff check out
Conditional Formatting is applied to cells
the ones in Yellow shows those who are taking more than 30 min in their lunchtime and obviously haven't been checked out.
Hope this helps
Regards
Jeovany
50 additional answers
    2020-04-23T05:16:01+00:00
    Oh yeah,
    I got it,
    We suggested Debbie, she should get 2 scanners
    Thanks Rohn
    2020-04-23T14:45:33+00:00
    Wow, this looks awesome!
    We do have two scanners. I will play around with the file.
    Thank you so much!
    2020-04-27T12:51:24+00:00
    Thank you so much!
    Hi Debbie
    I hope you are OK and Healthy
    We haven't heard from you in a few days.
    Could you give us some updates regarding the file I sent you?
    Did you have any issues with the file?
    How does your "playing around" goes?
    Do let us know if the file and the answer helped you
    If so then please,
    Consider marking this thread as answered.
    It would help others in the community with similar questions or problems.
    Thank you in advance
    Regards
    Jeovany
    2020-05-02T02:10:34+00:00
    Hi Jeovany!
    I am safe and I played with the file, we tried it with two scanners, we did a test with people and it worked marvelously!
    We are so thankful for your help, you saved us!
    I did click on that but it seems it did not work, I will do it again.
