Create a seat assigner with Excel and RFID
2020-04-16T23:26:27+00:00
Due to Covid19, we are tracking who sits with who in the cafeteria.
We have a simple Excel file that assigns a seat in the cafeteria to the employees based on the RFID. It is very simple, We have a Seat column with seats from 1-135, they scan their badge, the ID number appears on the ID column, then there is a name column with a Vlookup based on the ID that enters the name of the employee and that is it.
The issue we have is that, sometimes it assigns a seat that is still taken. I cannot think of a way in which the employee scans their badge again and the record is deleted from the seat number so that it is now free for someone else :S and doing that without losing the original records of where the person sat.
Any ideas would be highly appreciatted
2020-04-23T05:33:48+00:00
@ Debbie.
I have no scanners here, so I typed in the ID numbers
1- Before the start
The SCAN sheet will look like this, The scanner will be focused on cell C3 Named range ScanID
2- After the first 10 scan (employees)
After the first 10 scan (employees) on each sheet
RECORD/TRACKING before any check-out.
3- After some of the staff check out
Conditional Formatting is applied to cells
the ones in Yellow shows those who are taking more than 30 min in their lunchtime and obviously haven't been checked out.
Hope this helps
Regards
Jeovany
50 additional answers
    2020-04-17T00:53:05+00:00
    Hi Debbie
    My suggestion so far
    1- Create a Time Out (Lunch Time End) column that will be filled once the employee scans his badge again
    2-Once it happens, then to use IF conditional functions with COUNTA(Time In column: Time Out column)=2
    to Uncheck or show that the seat is Empty
    Unfortunately, we don't know the layout of your worksheet.
    To give you the right or more accurate solution to our problem please,
    provide us with a sample of your workbook (with no confidential or sensitive data),
    Upload the file to OneDrive, DropBox, Google Drive, etc and share the link to the file here.
    And give more details of your scenario ad your goals
    Regards
    Jeovany
    2020-04-17T02:13:53+00:00
    This is how it looks like right now :P It is very simple. It goes from 1 to 135 and then starts at 1 right after 135. We have three meal times.
    2020-04-17T05:15:54+00:00
    Thanks for the information
    What formula or method you use to assign the seats to the employees once they scan their badges.?
    I clearly understand the VLOOKUP part
    Could you explain us what do you mean by
    "The issue we have is that, sometimes it assigns a seat that is still taken. " ?
    2020-04-17T05:22:56+00:00
    Hi Debbie,
    I think it’s better to create a helper columns as mentioned by Jeovany and make a condition is such a way that whenever the employee scans the badge again, it will show up the seat is free to occupy.
    Here is the sample we think about:
    If I misunderstood your requirement, apologies for it and can you please provide some more detailed description of your requirement and share us the sample file by uploading to OneDrive to share the link to access it.
    Best Regards,
    Chitrahaas
