Hi Ossie
Thanks for that
I guess I didnt explain to well
so on my user form frmincident - data is inputted as per the form questions - the first question is incident data - which is in a normal text box - the user in puts the data as dd/mm/yyyy - on completion of the entries the user presses save and the data
is transferred on to the worksheet - thats all fine - im using this vba
Sub Submit()
Dim sh As Worksheet
Dim irow As Long
Set sh = ThisWorkbook.Sheets("Database")
If frmincident.txtRowNumber.Value = "" Then
irow = [Counta(Database!A:A)] + 1
Else
irow = frmincident.txtRowNumber.Value
End If
With sh
.Cells(irow, 1) = "=Row()-2" 'Dynamic Serial Number
.Cells(irow, 2) = frmincident.txtcomment.Value
.Cells(irow, 3) = frmincident.cmbdelay.Value
.Cells(irow, 5) = frmincident.txtfinished.Value
.Cells(irow, 7) = frmincident.txtarrival.Value
.Cells(irow, 9) = frmincident.txtturnout.Value
.Cells(irow, 11) = frmincident.txtdispatch.Value
.Cells(irow, 12) = frmincident.cmbproperty.Value
.Cells(irow, 13) = frmincident.cmbincident.Value
.Cells(irow, 14) = frmincident.cmbcommunity.Value
.Cells(irow, 15) = frmincident.cmbstation.Value
.Cells(irow, 16) = frmincident.cmbcall.Value
.Cells(irow, 17) = frmincident.txttime.Value
.Cells(irow, 18) = frmincident.txtdate.Value
.Cells(irow, 19) = frmincident.txtautomax.Value
.Cells(irow, 20) = Application.UserName
.Cells(irow, 21) = [Text(Now(),"DD-MM-YYYY HH:MM:SS")]
End With
End Sub
That works and the Date format is correct at that point
Then also within a list box on the user form the inputted data is also visualised as per
.LstDatabase.ColumnCount = 21
.LstDatabase.ColumnHeads = True
.LstDatabase.ColumnWidths = "20,80,120,92,100,90,95,120,90,110,120,90,85,90,90,70,60,70,110,80,80,80,80"
If irow > 1 Then
.LstDatabase.RowSource = "Database!A2:T" & irow
Else
.LstDatabase.RowSource = "Database!A2:T2"
End If
End With
End Sub
Now this is when the issue occurs - if you select any of the entries from the list box for editing by selecting the list box entry and pressing a cmd button
and this runs
Private Sub cmdedit_Click()
If Selected_List = 0 Then
MsgBox "No Row is Selected.", vbOKOnly + vbInformation, "Edit"
Exit Sub
End If
'Code to update the value to respective controls
Me.txtRowNumber.Value = Application.WorksheetFunction.Match(Me.LstDatabase.List(Me.LstDatabase.ListIndex, 0), _
ThisWorkbook.Sheets("Database").Range("A:A"), 0) 'Selected_List + 1
Me.txtcomment.Value = Me.LstDatabase.List(Me.LstDatabase.ListIndex, 1)
Me.cmbdelay.Value = Me.LstDatabase.List(Me.LstDatabase.ListIndex, 2)
Me.txtfinished.Value = Me.LstDatabase.List(Me.LstDatabase.ListIndex, 4)
Me.txtarrival.Value = Me.LstDatabase.List(Me.LstDatabase.ListIndex, 6)
Me.txtturnout.Value = Me.LstDatabase.List(Me.LstDatabase.ListIndex, 8)
Me.txtdispatch.Value = Me.LstDatabase.List(Me.LstDatabase.ListIndex, 10)
Me.cmbproperty.Value = Me.LstDatabase.List(Me.LstDatabase.ListIndex, 11)
Me.cmbincident.Value = Me.LstDatabase.List(Me.LstDatabase.ListIndex, 12)
Me.cmbcommunity.Value = Me.LstDatabase.List(Me.LstDatabase.ListIndex, 13)
Me.cmbstation.Value = Me.LstDatabase.List(Me.LstDatabase.ListIndex, 14)
Me.cmbcall.Value = Me.LstDatabase.List(Me.LstDatabase.ListIndex, 15)
Me.txttime.Value = Me.LstDatabase.List(Me.LstDatabase.ListIndex, 16)
Me.txtdate.Value = Me.LstDatabase.List(Me.LstDatabase.ListIndex, 17)
Me.txtautomax.Value = Me.LstDatabase.List(Me.LstDatabase.ListIndex, 18)
MsgBox "Please make the required changes and click 'Save' button to update.", vbOKOnly + vbInformation, "Edit"
End Sub
so this is when the problem occurrs so if there is a date such 06/12/2020 the entry ti the txtdate box comes back as number eg 09/01/2020 now shows as 43839
Can you offer any further guidance please ?
I have a further problem which is also similar with time - if the excel works sheet is not formatted as a text cell the value returns - as a decimal - so if the cells are formated as 'TIME' hh:mm it will not return a time format from the user form list
box into the relevant txtboxes
Thank you
