Using any Building Block triggers warning message about changes to Building Blocks.dotx Page Numbers, Cover Page, Header, Footer, Text Box
2019-10-30T21:05:40+00:00
I have a template that uses a custom TOC, custom headers/footers, custom cover pages, custom AutoText that's used for Building Block Gallery content controls, etc. All these elements are saved as building blocks in the template file itself, not in Building Blocks. However, after I, and also other users, interact with any of these elements either in the template itself or in a Word document generated from it, we now receive the following warning message when we close Word:
This issue seems to be linked especially to selection of a different option in Building Block Gallery content controls. Even just looking at, but not changing, a control's properties from the Developer tab is enough to cause this warning to appear.
We've used the same template for several years now and never received this warning message until recently. I've double-checked all the custom building blocks in the Building Blocks Organizer dialog box, and they're all definitely saved in the template file itself. Has something changed in the way that Word handles building blocks, AutoText, and/or Building Block Gallery content controls? How do I need to update my template to prevent this warning message from appearing?
* EDIT BY MODERATOR (CHARLES KENYON) TO ADD INFORMATION ABOUT SCOPE OF PROBLEM 26 DEC 2019
This is a lengthy thread. To summarize:
**This warning will appear, without any changes to the Building Blocks.dotx file, whenever the user accesses a building block contained in that file or uses the Quick Parts menu.**An analysis by MVP Greg Maxey shows that these actions load the file and when it is loaded, even though not changed, its saved status is changed to unsaved. That is what triggers the warning.
This applies to Windows versions 1908-1912 of Word 2016-2019/365. It does not happen with Word 2010/2013.
* EDIT BY MODERATOR (CHARLES KENYON)  1/15/2020
It appears this is being fixed. Release 2001 (Insider Monthly) does not have the problem.
2019-11-06T12:59:54+00:00
Sorry for the inconvenience caused by this issue, I have reproduced the issue in my tests following the steps from Charles, and I found the problem occurs only in Version 1910. So as a current workaround, I suggest you revert back to version 1909 or older, and here's the reference:
How to revert to an earlier version of Office 2016 Click-to-Run
In the meantime, you could click File->Feedback to let PG notice this strange behavior.
I would do more tests on the insider channel, and thank you for your understanding and patience.
Have a nice day.
Best Regards,
Oliver
*EDITED: This behavior appears in version 1911 and 1912 Insider Channel.
*EDITED by another moderator (Charles Kenyon) to add information. 26 Dec 2019
I have gotten impatient, like the person waiting for an elevator who keeps pushing the button.
I've added a suggestion to UserVoice and sent in my own feedback.
For anyone who wants to vote for the UserVoice suggestion, here is a link.
A workaround macro was suggested by Greg Maxey on December 26, 2019. It should be helpful. On my browser that shows up on page 5 of this thread.
End of CK Edit.
Edited by Charles Kenyon again (1/16/2020). Good news! Version 2001 (Insider Monhtly) appears to have fixed this. Still fixed in 2002.
2019-12-26T17:03:12+00:00
Charles,
  It isn't inserting the DocProperty CC that triggers this warning.  What happens is when you click the "QuickParts" control on the Insert tab or any other BuildingBlock gallery (including BuidlingBlock Gallery content controls), the "Building Blocks.dotx" and "Built-In Building Blocks.dotx templates are loaded. You can see this a a brief pause (sometimes a circling cursor) as they load.
For proof, open Word from scratch and run this code.  You shouldn't see either Building Blocks or Built-In Building Blocks loaded.  Then simply click the "QuickParts" menu control without doing anything else.  Then run the code again.  You will see both are now loaded and the saved state of "Building Blocks.dotx" is set as false.  That is clearly the bug.
Sub ScratchMacro()
'A basic Word macro coded by Greg Maxey
Dim oTmp As Template
  For Each oTmp In Templates
    Debug.Print oTmp.Name & " --- " & oTmp.Saved
  Next
lbl_Exit:
  Exit Sub
End Sub
Like I said, I typically use Word 2010 but now that I know about this issue, I've handled it by adding an AutoClose macro to my Normal.dotm. I figure if I make a change to Building Blocks.dotx then I would want it saved so rather than be asked if I want to save it whether I changed it or not, I just make sure it is saved when closing Word and not worry about it :-)
Sub AutoClose()
    If oTmp.Name = "Building Blocks.dotx" Then
      oTmp.Save
      Exit For
    End If
  Next
lbl_Exit:
  Exit Sub
End Sub
51 additional answers
  1. Charles Kenyon 171.1K Reputation points Volunteer Moderator
    2019-12-26T02:40:24+00:00
    Greg,
    Thanks for the information. I just noticed that inserting one of the Document Property CCs triggers the warning. On the other hand, inserting a plain text CC using the developer tab or using your Custom Content Control Insert Dialog to create a mapped plain text CC does not trigger the warning.
    I have not tested for the saved property.
    What I and others have been seeing does not need anything to do with Content Controls, though. Simply looking at the Building Blocks Organizer and closing it will trigger the warning.
    Using a building block or AutoText stored in a separate global template will not as of today. This includes at least AutoText in the normal template.
    OTOH, storing AutoText in the Normal Template using Alt+F3 will trigger both the Building Blocks.dotx warning as well as the normal template warning.
  2. Charles Kenyon 171.1K Reputation points Volunteer Moderator
    2019-12-26T17:22:48+00:00
    Your macro looks like a good workaround for those who find it.
    Through your analysis, you've done the heavy lifting for anyone at Microsoft who cares to fix this bug.
    I've added a suggestion to UserVoice and sent in my own feedback. I had assumed that Oliver had escalated this to developers and that may be the case.
    https://word.uservoice.com/forums/304924-word-for-windows-desktop-application/suggestions/39324181-stop-warning-whenever-any-building-block-is-used
    Feel free to add comments.
    2020-01-16T18:40:30+00:00
    Quick heads up. I have users still on 1912 with this issue. Has there been a new patch that fixes this issue yet? Searching for updates returns no new build so far.
    Just wanted to make sure the developers and moderators know it's still an issue as of Jan 16, 2020.
