The only solution is to delte and re install WORD? I bought this Dell Computer less than a year ago with WORD already installed so
i don't have a disc.
I did everything the 1st responder mentioned about extracting all............ however it didn't work when i went to type in that specific font even though it is listed in the WORD pull down menu. So frustrated.
If the problem is with a specific font, only, reinstalling Office is hardly worth the effort. Just use some other font which is working properly.
Finding a half-way solution is not always the best option, as you may have a job that requires these specific fonts since the file was created with them. You can't always substitute unless you want to re-format the whole book or whatever. And since what
was suggested earlier is the PROPER way of solving the problem, why not use it? Shame it cannot be found on the MS official help site. I'll quote it again:
Be sure to extract the font from a zip file if it came that way. The option to install or
install for all users will not be available if the font is still inside a zip file.
Windows 10 makes it easy, though. In File Explorer, browse into the zip file to the font file. At the top of File Explorer, click the Extract (Compressed Folder Tools), then click Extract all. Follow the prompts, then, when the files are extracted,
right-click and Install for All Users.
