Fonts not working on Microsoft word
2019-07-31T13:09:19+00:00
I've installed a few fonts that I want to use in Microsoft Word 365. They are open type fonts. They show up in my font selection choices in Microsoft Word but when I start to type it does not use the correct font. It uses a generic font. I know that it isn't a problem with the font itself because it works in other programs. Any solutions?
2019-12-18T13:30:18+00:00
Be sure to extract the font from a zip file if it came that way. The option to install or install for all users will not be available if the font is still inside a zip file.
Windows 10 makes it easy, though. In File Explorer, browse into the zip file to the font file. At the top of File Explorer, click the Extract (Compressed Folder Tools), then click Extract all. Follow the prompts, then, when the files are extracted, right-click and Install for All Users.
40 additional answers
    2019-12-06T02:50:05+00:00
    trying to solve same problem..... Right click on what for "Install for all users"
    Thank you
    Once you've downloaded the font, if it is in a zip file, you need to extract it.  Once its extracted, you go to the folder where you've extracted your font and right click on the font's file.  You will see several choices, but two of them are "install" and "install for all users."  Make sure you click on "Install for all users."
    2019-12-06T17:32:48+00:00
    unfortunately i'm not seeing the "install or "install for all users" by right clicking.
    If i actually open the TFF than the type example window opens and gives me an option
    at top left to either print or install.
    If i "install" than yes it shows up in my WORD menu type option but does not actually
    show up on the typed document as that particular font.......... just generic.
    So somewhere i am missing a big step.
    I'm studying and studying this.......... frustrating.
    Thank you
    Sandy
    2019-12-12T08:03:18+00:00
    Same here... Everything is up to date, everything SHOULD work just fine, but the FONTS DO NOT!!!
    2019-12-18T13:49:54+00:00
    For all those wondering. I was able to get it working again. I can't remember exactly how, but I think I deleted microsoft word and reinstalled it.
