Fonts not working on Microsoft word
2019-07-31T13:09:19+00:00
I've installed a few fonts that I want to use in Microsoft Word 365. They are open type fonts. They show up in my font selection choices in Microsoft Word but when I start to type it does not use the correct font. It uses a generic font. I know that it isn't a problem with the font itself because it works in other programs. Any solutions?
2019-12-18T13:30:18+00:00
Be sure to extract the font from a zip file if it came that way. The option to install or install for all users will not be available if the font is still inside a zip file.
Windows 10 makes it easy, though. In File Explorer, browse into the zip file to the font file. At the top of File Explorer, click the Extract (Compressed Folder Tools), then click Extract all. Follow the prompts, then, when the files are extracted, right-click and Install for All Users.
40 additional answers
    2019-11-08T17:54:05+00:00
    I am having the same issues.  I have several fonts that are essential in my work that are not working in any Office product, but have no issues in Adobe.  I have followed all the fixes from uninstalling and reinstalling the fonts and repairing the Office products.  Nothing works to get the fonts to work in Office.
    Again, they show up in the font settings and when test-typing, they work perfectly. They show up and can be used normally in Adobe. But while they show up in Office products on the font pull-down list, they default to generic when attempting to use them.
    I will point out that they worked fine in the past, but it seems that a recent Windows update may have rendered them unusable.
    2019-11-11T13:13:13+00:00
    Same issue here as well. Fonts that were working in Office as recently as a week ago have suddenly stopped working. They continue to work as normal in Adobe, however in Office they show up in the font selector but revert to a generic font when in use.
    For one of the fonts in question, Raleway, it seems that all the italic font types work, but the regular does not.
    2019-11-19T05:36:30+00:00
    I have exactly the same issue. Downloaded a few fonts a few months ago - essential for my business. They were working correctly and were preserved when saving pdfs etc.
    Then suddenly, after an update, they stopped working - the fonts appear in the drop down menu in office products, but they default to standard fonts if selected and aren't preserved when saving as pdfs.
    I have tried many suggested fixes but nothing works.
    Please help Microsoft!!!!
  4. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2019-11-19T06:41:44+00:00
    Do the fonts work properly if, as soon as creating the document, you save it in Word 97-2003 (*.doc) format?
