Fonts not working on Microsoft word
2019-07-31T13:09:19+00:00
I've installed a few fonts that I want to use in Microsoft Word 365. They are open type fonts. They show up in my font selection choices in Microsoft Word but when I start to type it does not use the correct font. It uses a generic font. I know that it isn't a problem with the font itself because it works in other programs. Any solutions?
2019-12-18T13:30:18+00:00
Be sure to extract the font from a zip file if it came that way. The option to install or install for all users will not be available if the font is still inside a zip file.
Windows 10 makes it easy, though. In File Explorer, browse into the zip file to the font file. At the top of File Explorer, click the Extract (Compressed Folder Tools), then click Extract all. Follow the prompts, then, when the files are extracted, right-click and Install for All Users.
40 additional answers
  1. Stefan Blom 353.7K Reputation points MVP Volunteer Moderator
    2019-10-22T05:35:00+00:00
    What is the name of the specific font? Does it work as expected in other programs?
    Also, which versions of Word and Windows are you running?
    2019-10-22T19:24:24+00:00
    I have this exact same problem.  I am using a font that I installed from an otf file.  I am using whatever is the current version of word downloaded from my Microsoft account.  I have restarted my computer and Word.  The font works just fine in the adobe design programs. It shows up as is should in the sample from the drop down font selector menu of Word.  However, when I type, the correct font is not reflected on the Word document.  Instead, it shows default characters from another font.
    2019-10-26T21:57:38+00:00
    Exactly the same problem I'm having with Futura Font. All other updated versions of Futura work except for the original PT Light/Book/Medium/Demi/Bold. They can't be reinstalled or updated. Incredibly frustrating!!
    2019-11-01T16:17:31+00:00
    I am having the same issue. The font (Oswald) is
    1. installed correctly
    2. up to date
    3. is a .ttf file
    4. is recognized by Word -- displayed in the available fonts list in the left corner, in the correct font
    However, when it is selected, what I type in the body of the document does not appear in that font. Nor am I able to select text and change to that font.
    When I save to PDF, it does not save in the selected font.
    I am running Windows 10 Home, version 1809.
    I have repaired, reset and reinstalled Word with no success.
    Please help. This font is essential to my business.
