Microsoft 2016 for Mac Products Crash When Opening
2019-03-11T19:33:38+00:00
Hi there, my Outlook, Excel, and PowerPoint applications crash right after I open them. I can't even access the File/Help/etc menu because the Microsoft Error Reporting prompt opens immediately, and prevents the application's menu bar from opening.
I'm using Mac Mojave v 10.14.3 - the most updated version - and as many have suggested, I went into Microsoft 'Check for Updates' through my Word application (the one that will open), and found I'm using the most updated version.
I've also restarted my Mac and opened in safe mode with no difference.
Here are the crash logs below.
What should I do from here?
Thanks so much!
________
Microsoft Error Reporting log version: 2.0
Error Signature:
Exception: EXC_BAD_ACCESS
ExceptionEnumString: 1
Exception Code: KERN_INVALID_ADDRESS (0x0000000000000000)
Date/Time: 2019-03-11 19:09:23 +0000
Application Name: Microsoft Excel
Application Bundle ID: com.microsoft.Excel
Application Signature: XCEL
Application Bitness: x64
Application Version: 16.16.7.19021001
Crashed Module Name: mso99
Crashed Module Version: 16.16.7.190210
Crashed Module Offset: 0x0000000000021ab6
Blame Module Name: mso99
Blame Module Version: 16.16.7.190210
UnsymbolicatedChecksum: FA4DBFDEDB1ECCDA29EC2FD8B06D1F9D
Blame Module Offset: 0x0000000000021ab6
StackHash: 728583b1ff983970-SB_1_bk
Application LCID: 1033
Extra app info: Reg=en Loc=0x0409
Build Type: SHIP
Crashed thread Stack Pointer: 0x_00007000092caaa0
Audience: Insiders
AudienceGroup: Insiders
AudienceChannel: CC
Crashed thread: 14
Error Signature:
Date/Time: 2019-03-11 19:09:43 +0000
Application Name: Microsoft Outlook
Application Bundle ID: com.microsoft.Outlook
Application Signature: OPIM
Build Type: SHIP
Crashed thread Stack Pointer: 0x_0000700000b58aa0
Audience: Insiders
AudienceChannel: CC
Crashed thread: 6
Microsoft 365 and Office | Excel | For home | MacOS
Jim G 134K Reputation points MVP
2019-03-13T02:18:31+00:00
Hi Michael,
As you probably already know, the 16.16.8 update is now available and this problem has been fixed.
If you have AutoUpdate set to automatically install updates, it is likely this update was automatically installed.
If you have AutoUpdate set to manual updates, you can launch AutoUpdate from any Office application and choose Check for Updates from the Help menu. If none of your applications will open, you can download the update to AutoUpdate manually from this link, then install and run AutoUpdate, which will install the 16.16.8 fixed update to Microsoft Office 2016.
https://go.microsoft.com/fwlink/p/?linkid=830196
I highly recommend that anyone affected launch AutoUpdate by going to the Help menu in any Office 2016 application and choosing Check for Updates. Remove your installation from Insider programs by unchecking the box that has you join the program. There will never be any future Insider builds of Office for Office 2016. The feature set of Office 2016 is not going to change, and there will never be any future Insider builds.
142 additional answers
    2019-03-12T13:03:57+00:00
    This has saved my working day!
    2019-03-12T13:04:10+00:00
    I encountered crashes on all Microsoft Office applications only this morning after using Word, PowerPoint and Outlook all day yesterday with no problems. I made no changes between then and now, other than having restarted my computers. Same problem exists on both my Mackbook Pro laptop and my iMac desktop, running High Sierra 10.13.6.
    I've checked the "Notify Me" below, but it's unclear as to how I'll receive notifications under the circumstances.
    Here is partial content of the log from my iMac:
    Error Signature:
    Date/Time: 2019-03-12 13:00:36 +0000
    Application Name: Microsoft PowerPoint
    Application Bundle ID: com.microsoft.Powerpoint
    Application Signature: PPT3
    Build Type: SHIP
    Crashed thread Stack Pointer: 0x_00007000036ed9d0
    Audience: Insiders
    AudienceChannel: CC
    Crashed thread: 5
    Operating System Information
    Operating System: Mac OS X 10.13.6 (Build 17G5019)
    CPU: Intel x86, Logical CPU Count: 4, Frequency: 3400 MHz
    Physical Memory: 8192 MB
    Device_model: iMac14,2
    Screen: 2048.000000 x 1152.000000, bitsPerPixel = 24, frame = 0.000000, 0.000000, 2048.000000, 1152.000000
    Microsoft Application Information:
    ErrorReportingDeviceUUID: A4F467E5-9781-51B5-BF9F-F46BA92B15DF
    ErrorReportingUUID: B16F06E0-BA98-4F05-84BD-591CF7768308
    ULS UUID: 681923A6-1554-4E12-8E91-5FF92F298678
    CrashedLogSessionId: 681923A6-1554-4E12-8E91-5FF92F298678
    TimeFromLaunch: 0 hours, 0 minutes, 0 seconds
    CrashedSessionDuration: 0
    Total errors on this client: 38
    CrashedApp_Virtual_Memory_Size_MB: 4968.492
    CrashedApp_Resident_Memory_Size_MB: 99.85937
    2019-03-12T13:23:28+00:00
    Every time I attempt to print or save my document, the program crashes and stops responding. I've tried using both Word and Power point and have the same issue. I've tried restarting the program and accessing the program in safe mode and I have the same problem.
    TA
    2019-03-12T13:36:22+00:00
    Have the same issue with outlook 2016 latest update, am running Mojave 10.14.3 (18D109).
    Any ideas on a timeline and if we should expect a fix from MS or Apple?
