Microsoft 2016 for Mac Products Crash When Opening
2019-03-11T19:33:38+00:00
Hi there, my Outlook, Excel, and PowerPoint applications crash right after I open them. I can't even access the File/Help/etc menu because the Microsoft Error Reporting prompt opens immediately, and prevents the application's menu bar from opening.
I'm using Mac Mojave v 10.14.3 - the most updated version - and as many have suggested, I went into Microsoft 'Check for Updates' through my Word application (the one that will open), and found I'm using the most updated version.
I've also restarted my Mac and opened in safe mode with no difference.
Here are the crash logs below.
What should I do from here?
Thanks so much!
________
Microsoft Error Reporting log version: 2.0
Error Signature:
Exception: EXC_BAD_ACCESS
ExceptionEnumString: 1
Exception Code: KERN_INVALID_ADDRESS (0x0000000000000000)
Date/Time: 2019-03-11 19:09:23 +0000
Application Name: Microsoft Excel
Application Bundle ID: com.microsoft.Excel
Application Signature: XCEL
Application Bitness: x64
Application Version: 16.16.7.19021001
Crashed Module Name: mso99
Crashed Module Version: 16.16.7.190210
Crashed Module Offset: 0x0000000000021ab6
Blame Module Name: mso99
Blame Module Version: 16.16.7.190210
UnsymbolicatedChecksum: FA4DBFDEDB1ECCDA29EC2FD8B06D1F9D
Blame Module Offset: 0x0000000000021ab6
StackHash: 728583b1ff983970-SB_1_bk
Application LCID: 1033
Extra app info: Reg=en Loc=0x0409
Build Type: SHIP
Crashed thread Stack Pointer: 0x_00007000092caaa0
Audience: Insiders
AudienceGroup: Insiders
AudienceChannel: CC
Crashed thread: 14
Error Signature:
Date/Time: 2019-03-11 19:09:43 +0000
Application Name: Microsoft Outlook
Application Bundle ID: com.microsoft.Outlook
Application Signature: OPIM
Build Type: SHIP
Crashed thread Stack Pointer: 0x_0000700000b58aa0
Audience: Insiders
AudienceChannel: CC
Crashed thread: 6
Microsoft 365 and Office | Excel | For home | MacOS
Jim G 134K Reputation points MVP
2019-03-13T02:18:31+00:00
Hi Michael,
As you probably already know, the 16.16.8 update is now available and this problem has been fixed.
If you have AutoUpdate set to automatically install updates, it is likely this update was automatically installed.
If you have AutoUpdate set to manual updates, you can launch AutoUpdate from any Office application and choose Check for Updates from the Help menu. If none of your applications will open, you can download the update to AutoUpdate manually from this link, then install and run AutoUpdate, which will install the 16.16.8 fixed update to Microsoft Office 2016.
https://go.microsoft.com/fwlink/p/?linkid=830196
I highly recommend that anyone affected launch AutoUpdate by going to the Help menu in any Office 2016 application and choosing Check for Updates. Remove your installation from Insider programs by unchecking the box that has you join the program. There will never be any future Insider builds of Office for Office 2016. The feature set of Office 2016 is not going to change, and there will never be any future Insider builds.
142 additional answers
    2019-03-13T21:03:19+00:00
    Hi Papersculpture,
    We are still working on this issue. It happens to all Office applications for Volume license users. We have no updates yet. Please keep monitoring this thread.
    Ran
    Hi Ran,
    Is there some Microsoft / Support website where we can look for updates on this issue?
    2019-03-13T22:26:11+00:00
    Thanks so much!
    ________
    Error Signature:
    Build Type: SHIP
    Audience: Insiders
    AudienceChannel: CC
    Crashed thread: 14
    Error Signature:
    Build Type: SHIP
    Audience: Insiders
    AudienceChannel: CC
    Crashed thread: 6
    2019-03-13T23:15:52+00:00
    Hi Sujit,
    The issue has been fixed in the version 16.16.8. If you have updated to this version and are still experiencing a similar issue, I would suggest you post a new thread in our forum so that we can help you further troubleshoot.
    Ran
    2019-03-13T23:41:06+00:00
    Hi Ran,
    I cannot update to 16.16.8 as I'm on the Office 365 update cycle, which is currently at 16.23 (https://docs.microsoft.com/en-us/officeupdates/update-history-office-for-mac).
    Here is a partial stack trace. Could you send me a link where I can upload full crash logs?
    Error Signature:
    Exception Code: KERN_CODESIGN_ERROR (0x000000012b4c2d02)
    Date/Time: 2019-03-13 21:00:20 +0000
    Application Name: Microsoft Outlook-16.23
    Application Version: 16.23.0.19030902
    Crashed Module Name: unknown
    Crashed Module Version: 16.23.0.190309
    Crashed Module Offset: unknown
    Blame Module Name: unknown
    Blame Module Version: 16.23.0.190309
    UnsymbolicatedChecksum: unknown
    Blame Module Offset: unknown
    StackHash: unknown
    Build Type: Release
    Crashed thread Stack Pointer: 0x_000000012b500ffc
    Crashed thread: 20
