Microsoft 2016 for Mac Products Crash When Opening
2019-03-11T19:33:38+00:00
Hi there, my Outlook, Excel, and PowerPoint applications crash right after I open them. I can't even access the File/Help/etc menu because the Microsoft Error Reporting prompt opens immediately, and prevents the application's menu bar from opening.
I'm using Mac Mojave v 10.14.3 - the most updated version - and as many have suggested, I went into Microsoft 'Check for Updates' through my Word application (the one that will open), and found I'm using the most updated version.
I've also restarted my Mac and opened in safe mode with no difference.
Here are the crash logs below.
What should I do from here?
Thanks so much!
________
Microsoft Error Reporting log version: 2.0
Error Signature:
Exception: EXC_BAD_ACCESS
ExceptionEnumString: 1
Exception Code: KERN_INVALID_ADDRESS (0x0000000000000000)
Date/Time: 2019-03-11 19:09:23 +0000
Application Name: Microsoft Excel
Application Bundle ID: com.microsoft.Excel
Application Signature: XCEL
Application Bitness: x64
Application Version: 16.16.7.19021001
Crashed Module Name: mso99
Crashed Module Version: 16.16.7.190210
Crashed Module Offset: 0x0000000000021ab6
Blame Module Name: mso99
Blame Module Version: 16.16.7.190210
UnsymbolicatedChecksum: FA4DBFDEDB1ECCDA29EC2FD8B06D1F9D
Blame Module Offset: 0x0000000000021ab6
StackHash: 728583b1ff983970-SB_1_bk
Application LCID: 1033
Extra app info: Reg=en Loc=0x0409
Build Type: SHIP
Crashed thread Stack Pointer: 0x_00007000092caaa0
Audience: Insiders
AudienceGroup: Insiders
AudienceChannel: CC
Crashed thread: 14
Error Signature:
Date/Time: 2019-03-11 19:09:43 +0000
Application Name: Microsoft Outlook
Application Bundle ID: com.microsoft.Outlook
Application Signature: OPIM
Build Type: SHIP
Crashed thread Stack Pointer: 0x_0000700000b58aa0
Audience: Insiders
AudienceChannel: CC
Crashed thread: 6
Microsoft 365 and Office | Excel | For home | MacOS
Jim G 134K Reputation points MVP
2019-03-13T02:18:31+00:00
Hi Michael,
As you probably already know, the 16.16.8 update is now available and this problem has been fixed.
If you have AutoUpdate set to automatically install updates, it is likely this update was automatically installed.
If you have AutoUpdate set to manual updates, you can launch AutoUpdate from any Office application and choose Check for Updates from the Help menu. If none of your applications will open, you can download the update to AutoUpdate manually from this link, then install and run AutoUpdate, which will install the 16.16.8 fixed update to Microsoft Office 2016.
https://go.microsoft.com/fwlink/p/?linkid=830196
I highly recommend that anyone affected launch AutoUpdate by going to the Help menu in any Office 2016 application and choosing Check for Updates. Remove your installation from Insider programs by unchecking the box that has you join the program. There will never be any future Insider builds of Office for Office 2016. The feature set of Office 2016 is not going to change, and there will never be any future Insider builds.
142 additional answers
    2019-03-12T21:05:19+00:00
    ~/Library means the one in your home directory (/Users/username/Library).
    2019-03-12T21:11:11+00:00
    Please, someone, uncheck this reply as being "The Answer."
    Michael, we've had a lot of exchanges, so please see my recent reply that begins "Thank you for your patient reply," which, in essence, indicates that re-installing didn't solve the problem.
    Also, I located the Group Container file. It's not simply in the Library of the Mac. It's in the hidden Library of the user folder. There are no com.microsoft... files at all!
    For what it's worth, my Office 2016 isn't a subscription. It's a Student/Home purchase—a download just the same, but that might explain why I have no com.microsoft... files? I don't understand. Anyway, it seems that I have no option but to wait for Microsoft to solve the problem with an update.
    2019-03-12T21:19:33+00:00
    I agree that the way the post is written, it's not "The Answer", instead you have to look through his other posts.
    I DO believe that you can fix it though IF you can get an older version like my previous post which I'll put here.
    Deleting MicrosoftRegistrationDB.reg worked for me, but instead of uninstalling I did what Jim Gordon said about restoring the version 16.16.6 "Microsoft Excel.app" and "Microsoft Word.app" from Time Machine.
    When I opened Word and Excel, I lost my "Recent" files and "Pinned" files though.  Therefore, I restored the "MicrosoftRegistrationDB.reg" file from last Friday's Time Machine and thankfully all my "Recent" files and "Pinned" files came back!
    2019-03-12T21:33:40+00:00
    I can confirm that this also solve the issue on my Mac.
