Microsoft 2016 for Mac Products Crash When Opening
2019-03-11T19:33:38+00:00
Hi there, my Outlook, Excel, and PowerPoint applications crash right after I open them. I can't even access the File/Help/etc menu because the Microsoft Error Reporting prompt opens immediately, and prevents the application's menu bar from opening.
I'm using Mac Mojave v 10.14.3 - the most updated version - and as many have suggested, I went into Microsoft 'Check for Updates' through my Word application (the one that will open), and found I'm using the most updated version.
I've also restarted my Mac and opened in safe mode with no difference.
Here are the crash logs below.
What should I do from here?
Thanks so much!
________
Microsoft Error Reporting log version: 2.0
Error Signature:
Exception: EXC_BAD_ACCESS
ExceptionEnumString: 1
Exception Code: KERN_INVALID_ADDRESS (0x0000000000000000)
Date/Time: 2019-03-11 19:09:23 +0000
Application Name: Microsoft Excel
Application Bundle ID: com.microsoft.Excel
Application Signature: XCEL
Application Bitness: x64
Application Version: 16.16.7.19021001
Crashed Module Name: mso99
Crashed Module Version: 16.16.7.190210
Crashed Module Offset: 0x0000000000021ab6
Blame Module Name: mso99
Blame Module Version: 16.16.7.190210
UnsymbolicatedChecksum: FA4DBFDEDB1ECCDA29EC2FD8B06D1F9D
Blame Module Offset: 0x0000000000021ab6
StackHash: 728583b1ff983970-SB_1_bk
Application LCID: 1033
Extra app info: Reg=en Loc=0x0409
Build Type: SHIP
Crashed thread Stack Pointer: 0x_00007000092caaa0
Audience: Insiders
AudienceGroup: Insiders
AudienceChannel: CC
Crashed thread: 14
Error Signature:
Date/Time: 2019-03-11 19:09:43 +0000
Application Name: Microsoft Outlook
Application Bundle ID: com.microsoft.Outlook
Application Signature: OPIM
Build Type: SHIP
Crashed thread Stack Pointer: 0x_0000700000b58aa0
Audience: Insiders
AudienceChannel: CC
Crashed thread: 6
Microsoft 365 and Office | Excel | For home | MacOS
Jim G 134K Reputation points MVP
2019-03-13T02:18:31+00:00
Hi Michael,
As you probably already know, the 16.16.8 update is now available and this problem has been fixed.
If you have AutoUpdate set to automatically install updates, it is likely this update was automatically installed.
If you have AutoUpdate set to manual updates, you can launch AutoUpdate from any Office application and choose Check for Updates from the Help menu. If none of your applications will open, you can download the update to AutoUpdate manually from this link, then install and run AutoUpdate, which will install the 16.16.8 fixed update to Microsoft Office 2016.
https://go.microsoft.com/fwlink/p/?linkid=830196
I highly recommend that anyone affected launch AutoUpdate by going to the Help menu in any Office 2016 application and choosing Check for Updates. Remove your installation from Insider programs by unchecking the box that has you join the program. There will never be any future Insider builds of Office for Office 2016. The feature set of Office 2016 is not going to change, and there will never be any future Insider builds.
142 additional answers
  1. Deleted
    2019-03-12T13:46:01+00:00
    Hi Ran,
    Any updates on this issue yet?
    Thanks!
    2019-03-12T13:54:27+00:00
    Same problem on my MacBook Pro.
    Outlook crash at start, impossible to use it. Same problem on Excel.
    Below the Outlook crash report.
    PowerPoint and Word works fine.
      Nome modello: MacBook Pro
      Identificatore modello: MacBookPro15,1
      Nome processore: Intel Core i7
      Velocità processore: 2,2 GHz
      Numero di processori: 1
      Numero totale di Core: 6
      Cache L2 (per Core): 256 KB
      Cache L3: 9 MB
      Memoria: 16 GB
      Versione Boot ROM: 220.240.2.0.0 (iBridge: 16.16.3133.0.0,0)
    MS OUTLOOK CRASH REPORT
    Error Signature:
    Date/Time: 2019-03-12 13:49:57 +0000
    Application LCID: 1040
    Extra app info: Reg=en Loc=0x0410
    Build Type: SHIP
    Crashed thread Stack Pointer: 0x_000070000a527aa0
    Audience: Insiders_DevMain
    AudienceChannel: DevMain
    Crashed thread: 10
    Thread 0:
    #  1  0x00007fff3da975db in FSMount::diskimage() + 0x00000001 (CarbonCore + 0x00000000000045db) 0x0000000000000000
    #  2  0x00007fff5126b1c2 in parseAttributeBuffer(__CFAllocator const*, unsigned char const*, unsigned char, attrlist const*, void const*, void**, _FileAttributes*, unsigned int*) + 0x00000DB3 (CoreServicesInternal + 0x00000000000051c2) 0x0000000000000000
    #  3  0x00007fff5126a10b in corePropertyProviderPrepareValues(__CFURL const*, __FileCache*, __CFString const* const*, void const**, long, void const*, __CFError**) + 0x0000034A (CoreServicesInternal + 0x000000000000410b) 0x00007ffedfdb0fd0
    #  4  0x00007fff51269d61 in prepareValuesForBitmap(__CFURL const*, __FileCache*, _FilePropertyBitmap*, __CFError**) + 0x00000168 (CoreServicesInternal + 0x0000000000003d61) 0x00007ffedfdb17e0
    #  5  0x00007fff5126ba95 in _FSURLCopyResourcePropertyForKeyInternal(__CFURL const*, __CFString const*, void*, void*, __CFError**, unsigned char) + 0x000000D6 (CoreServicesInternal + 0x0000000000005a95) 0x00007ffedfdb1c00
    #  6  0x00007fff3c79b3c3 in _CFURLCopyResourcePropertyForKey + 0x00000065 (CoreFoundation + 0x00000000000453c3) 0x00007ffedfdb1cc0
    #  7  0x00007fff3c7e4292 in -[NSURL getResourceValue:forKey:error:] + 0x000000BE (CoreFoundation + 0x000000000008e292) 0x00007ffedfdb1d10
    #  8  0x00007fff3eb2d0c6 in -[NSURL(NSURLPathUtilities) URLByAppendingPathComponent:] + 0x000000E8 (Foundation + 0x00000000000520c6) 0x00007ffedfdb1d60
    #  9  0x0000000112662a81 in  (mso99 + 0x0000000000011a81) 0x00007ffedfdb1da0
    10  0x00000001126628df in  (mso99 + 0x00000000000118df) 0x00007ffedfdb1e30
    11  0x00000001126627de in  (mso99 + 0x00000000000117de) 0x00007ffedfdb1e60
    12  0x0000000112663030 in  (mso99 + 0x0000000000012030) 0x00007ffedfdb1e90
    13  0x0000000112662fe3 in  (mso99 + 0x0000000000011fe3) 0x00007ffedfdb1eb0
    14  0x0000000112662df8 in  (mso99 + 0x0000000000011df8) 0x00007ffedfdb1ed0
    15  0x0000000112662da3 in  (mso99 + 0x0000000000011da3) 0x00007ffedfdb1f40
    16  0x00000001126617ed in  (mso99 + 0x00000000000107ed) 0x00007ffedfdb1f50
    17  0x0000000112661717 in  (mso99 + 0x0000000000010717) 0x00007ffedfdb1f80
    18  0x000000011266110f in  (mso99 + 0x000000000001010f) 0x00007ffedfdb1f90
    19  0x000000011152dfe0 in  (mso20 + 0x0000000000091fe0) 0x00007ffedfdb2060
    20  0x000000011152dc42 in  (mso20 + 0x0000000000091c42) 0x00007ffedfdb20f0
    21  0x000000011152d791 in  (mso20 + 0x0000000000091791) 0x00007ffedfdb21f0
    22  0x00000001114b21dd in  (mso20 + 0x00000000000161dd) 0x00007ffedfdb2230
    23  0x000000011265b367 in  (mso99 + 0x000000000000a367) 0x00007ffedfdb2270
    24  0x000000011266d8f5 in  (mso99 + 0x000000000001c8f5) 0x00007ffedfdb22c0
    25  0x0000000112666f13 in  (mso99 + 0x0000000000015f13) 0x00007ffedfdb2300
    26  0x000000011043a0f3 in  (Microsoft Outlook + 0x00000000005ee0f3) 0x00007ffedfdb2340
    27  0x000000010fe51b58 in  (Microsoft Outlook + 0x0000000000005b58) 0x00007ffedfdb2360
    28  0x000000010fe51af6 in  (Microsoft Outlook + 0x0000000000005af6) 0x00007ffedfdb23a0
    29  0x000000010fe51894 in  (Microsoft Outlook + 0x0000000000005894) 0x00007ffedfdb23c0
    30  0x00007fff3c7f5632 in ___CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 0x0000000C (CoreFoundation + 0x000000000009f632) 0x00007ffedfdb2470
    31  0x00007fff3c7f55ac in ____CFXRegistrationPost_block_invoke + 0x0000003F (CoreFoundation + 0x000000000009f5ac) 0x00007ffedfdb2480
    32  0x00007fff3c7f54cd in __CFXRegistrationPost + 0x0000018E (CoreFoundation + 0x000000000009f4cd) 0x00007ffedfdb24a0
    33  0x00007fff3c7fd929 in ____CFXNotificationPost_block_invoke + 0x00000057 (CoreFoundation + 0x00000000000a7929) 0x00007ffedfdb2510
    34  0x00007fff3c7650ca in -[_CFXNotificationRegistrar find:object:observer:enumerator:] + 0x00000661 (CoreFoundation + 0x000000000000f0ca) 0x00007ffedfdb2550
    35  0x00007fff3c76448d in __CFXNotificationPost + 0x000002E6 (CoreFoundation + 0x000000000000e48d) 0x00007ffedfdb2c70
    36  0x00007fff3eaeca7b in -[NSNotificationCenter postNotificationName:object:userInfo:] + 0x00000042 (Foundation + 0x0000000000011a7b) 0x00007ffedfdb2f00
    37  0x00007fff39ce964a in -[NSApplication _postDidFinishNotification] + 0x00000139 (AppKit + 0x000000000002264a) 0x00007ffedfdb2f30
    38  0x00007fff39ce8f6e in -[NSApplication _sendFinishLaunchingNotification] + 0x000000D1 (AppKit + 0x0000000000021f6e) 0x00007ffedfdb2f80
    39  0x00007fff39ce68c8 in -[NSApplication(NSAppleEventHandling) _handleAEOpenEvent:] + 0x00000228 (AppKit + 0x000000000001f8c8) 0x00007ffedfdb2fb0
    40  0x00007fff39ce6517 in -[NSApplication(NSAppleEventHandling) _handleCoreEvent:withReplyEvent:] + 0x000002B2 (AppKit + 0x000000000001f517) 0x00007ffedfdb3030
    41  0x00007fff3eb37144 in -[NSAppleEventManager dispatchRawAppleEvent:withRawReply:handlerRefCon:] + 0x0000011F (Foundation + 0x000000000005c144) 0x00007ffedfdb3080
    42  0x00007fff3eb36fc0 in __NSAppleEventManagerGenericHandler + 0x00000066 (Foundation + 0x000000000005bfc0) 0x00007ffedfdb30d0
    43  0x00007fff3da1cb93 in aeDispatchAppleEvent(AEDesc const*, AEDesc*, unsigned int, unsigned char*) + 0x0000073F (AE + 0x0000000000008b93) 0x00007ffedfdb3110
    44  0x00007fff3da1c3fd in dispatchEventAndSendReply(AEDesc const*, AEDesc*) + 0x00000029 (AE + 0x00000000000083fd) 0x00007ffedfdb32d0
    45  0x00007fff3da1c2d5 in _aeProcessAppleEvent + 0x000001B7 (AE + 0x00000000000082d5) 0x00007ffedfdb3310
    46  0x00007fff3ba3110e in _AEProcessAppleEvent + 0x00000037 (HIToolbox + 0x000000000001410e) 0x00007ffedfdb3380
    47  0x00007fff39ce2644 in __DPSNextEvent + 0x000006C6 (AppKit + 0x000000000001b644) 0x00007ffedfdb33c0
    48  0x00007fff39ce1102 in -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 0x00000552 (AppKit + 0x000000000001a102) 0x00007ffedfdb37d0
    49  0x00007fff39cdb165 in -[NSApplication run] + 0x000002BB (AppKit + 0x0000000000014165) 0x00007ffedfdb3a50
    50  0x00007fff39cca8a3 in _NSApplicationMain + 0x0000030C (AppKit + 0x00000000000038a3) 0x00007ffedfdb3b20
    51  0x00007fff699deed9 in _start + 0x00000001 (libdyld.dylib + 0x0000000000016ed9) 0x00007ffedfdb3b70
    x86_64 Thread State(64bit):
      __rax: 0x0000000000000001   __rbx: 0x0000000000000080   __rcx: 0x0000000000000080   __rdx:0x0000000000000000
      __rdi: 0x00007ffedfdb0ed0   __rsi: 0x000000001c200003   __rbp: 0x00007ffedfdb0ec0   __rsp:0x00007ffedfdb0ea0
      __r8: 0x00007ffedfdb0df0    __r9: 0x0000000000000000    __r10: 0x0000000000000000   __r11:0x0000000000000246
      __r12: 0x0000800000000000   __r13: 0x0000000000000000   __r14: 0x00007ffedfdb0ed0   __r15:0x0000000000000000
      __rip: 0x00007fff3da975db   __rflags: 0x0000000000000202   __cs: 0x000000000000002b   __fs:0x0000000000000000
      __gs: 0x0000000000000000
    Thread 1:
    #  1  0x00007fff69bc6700 in __platform_strlen + 0x00000000 (libsystem_platform.dylib + 0x0000000000001700) 0x0000000000000000
    #  2  0x00007fff4846a251 in _secLogObjForScope + 0x00000053 (Security + 0x0000000000278251) 0x0000000000000000
    #  3  0x00007fff4830f1e0 in SSKey::keyHandle() + 0x00000180 (Security + 0x000000000011d1e0) 0x000070000a08b600
    #  4  0x00007fff4831038d in SSCryptContext::init(Security::Context const&, bool) + 0x000000BF (Security + 0x000000000011e38d) 0x000070000a08b760
    #  5  0x00007fff482186c2 in Security::CSPFullPluginSession::init(unsigned long long, unsigned int, Security::Context const&, bool) + 0x00000072 (Security + 0x00000000000266c2) 0x000070000a08b790
    #  6  0x00007fff48333baa in cssm_DecryptDataInit(long, unsigned long long, cssm_context const*, unsigned long long) + 0x0000005C (Security + 0x0000000000141baa) 0x000070000a08b7e0
    #  7  0x00007fff483997f0 in _CSSM_DecryptDataInit + 0x0000007C (Security + 0x00000000001a77f0) 0x000070000a08b820
    #  8  0x00007fff4832d3c1 in Security::CssmClient::Decrypt::init() + 0x0000001B (Security + 0x000000000013b3c1) 0x000070000a08b860
    #  9  0x00007fff483308f2 in Security::CssmClient::SSGroupImpl::decodeDataBlob(cssm_data const&, cssm_access_credentials const*, Security::Allocator&, cssm_data&) + 0x000001B2 (Security + 0x000000000013e8f2) 0x000070000a08b880
    10  0x00007fff482160aa in Security::CssmClient::SSDbUniqueRecordImpl::get(Security::CssmClient::DbAttributes*, Security::CssmDataContainer*, cssm_access_credentials const*) + 0x00000110 (Security + 0x00000000000240aa) 0x000070000a08bb50
    11  0x00007fff483b8e14 in Security::KeychainCore::ItemImpl::getContent(Security::CssmClient::DbAttributes*, Security::CssmDataContainer*) + 0x00000206 (Security + 0x00000000001c6e14) 0x000070000a08bc40
    12  0x00007fff483bc9ed in Security::KeychainCore::ItemImpl::getContent(SecItemClass*, SecKeychainAttributeList*, unsigned int*, void**) + 0x00000431 (Security + 0x00000000001ca9ed) 0x000070000a08be90
    13  0x00007fff483fac6b in _SecKeychainItemCopyContent + 0x000000D2 (Security + 0x0000000000208c6b) 0x000070000a08c040
    14  0x00007fff483e1224 in AddItemResults(OpaqueSecKeychainItemRef*, OpaqueSecIdentityRef*, SecItemParams*, __CFAllocator const*, __CFArray**, void const**) + 0x00000236 (Security + 0x00000000001ef224) 0x000070000a08c0a0
    15  0x00007fff483df9e4 in SecItemCopyMatching_osx(__CFDictionary const*, void const**) + 0x00000BE3 (Security + 0x00000000001ed9e4) 0x000070000a08c360
    16  0x00007fff483e2590 in _SecItemCopyMatching + 0x0000015B (Security + 0x00000000001f0590) 0x000070000a08c430
    17  0x0000000111932cd5 in  (mso30 + 0x000000000002dcd5) 0x000070000a08c4a0
    18  0x00000001119328ca in  (mso30 + 0x000000000002d8ca) 0x000070000a08c800
    19  0x000000011192a9dc in  (mso30 + 0x00000000000259dc) 0x000070000a08c8b0
    20  0x000000011192a6ef in  (mso30 + 0x00000000000256ef) 0x000070000a08cb10
    21  0x000000011192a45a in  (mso30 + 0x000000000002545a) 0x000070000a08cb30
    22  0x000000011192a429 in  (mso30 + 0x0000000000025429) 0x000070000a08cbc0
    23  0x000000011192a3c4 in  (mso30 + 0x00000000000253c4) 0x000070000a08cbd0
    24  0x0000000111929880 in  (mso30 + 0x0000000000024880) 0x000070000a08cbf0
    25  0x000000011192955f in  (mso30 + 0x000000000002455f) 0x000070000a08ccb0
    26  0x0000000111928d08 in  (mso30 + 0x0000000000023d08) 0x000070000a08cd30
    27  0x000000011151e2c9 in  (mso20 + 0x00000000000822c9) 0x000070000a08cd50
    28  0x000000011151e0dc in  (mso20 + 0x00000000000820dc) 0x000070000a08cd80
    29  0x000000011151de49 in  (mso20 + 0x0000000000081e49) 0x000070000a08cda0
    30  0x000000011151dd62 in  (mso20 + 0x0000000000081d62) 0x000070000a08ce20
    31  0x00000001164b64c1 in  (WLMKernel + 0x00000000000184c1) 0x000070000a08ce40
    32  0x00007fff6998fd53 in __dispatch_call_block_and_release + 0x0000000C (libdispatch.dylib + 0x0000000000002d53) 0x000070000a08ce70
    33  0x00007fff69990dcf in __dispatch_client_callout + 0x00000008 (libdispatch.dylib + 0x0000000000003dcf) 0x000070000a08ce90
    34  0x00007fff69993240 in __dispatch_queue_override_invoke + 0x000002FF (libdispatch.dylib + 0x0000000000006240) 0x000070000a08ceb0
    35  0x00007fff6999ed26 in __dispatch_root_queue_drain + 0x00000145 (libdispatch.dylib + 0x0000000000011d26) 0x000070000a08cf10
    36  0x00007fff6999f4bd in __dispatch_worker_thread2 + 0x0000005A (libdispatch.dylib + 0x00000000000124bd) 0x000070000a08cf80
    37  0x00007fff69bd16dd in __pthread_wqthread + 0x0000026B (libsystem_pthread.dylib + 0x00000000000026dd) 0x000070000a08cf90
    38  0x00007fff69bd1405 in _start_wqthread + 0x0000000D (libsystem_pthread.dylib + 0x0000000000002405) 0x000070000a08cfd0
      __rax: 0x00007fff3c8fd450   __rbx: 0x00007fff48491e26   __rcx: 0x00007fff96a494d8   __rdx:0x0000000000000600
      __rdi: 0x00007fff48491e26   __rsi: 0x00007fff48491e26   __rbp: 0x000070000a08b5d0   __rsp:0x000070000a08b5a8
      __r8: 0x00000000000132fa    __r9: 0xffffffff00000000    __r10: 0x00007fff96a494d0   __r11:0x0000000000000246
      __r12: 0x00007f8e73652e88   __r13: 0x00007fff96a126a8   __r14: 0x0000000000000600   __r15:0x0000000000000000
      __rip: 0x00007fff69bc6700   __rflags: 0x0000000000000202   __cs: 0x000000000000002b   __fs:0x0000000000000000
    Thread 2:
    #  1  0x00007fff69bd13f8 in _start_wqthread + 0x00000000 (libsystem_pthread.dylib + 0x00000000000023f8) 0x0000000000000000
    #  2  0x0000000000000000 in  ( + 0x0000000000000000) 0x0000000000000000
      __rax: 0x0000000002000170   __rbx: 0x000070000a110000   __rcx: 0x000070000a10fb80   __rdx:0x000070000a090000
      __rdi: 0x000070000a110000   __rsi: 0x0000000000002703   __rbp: 0x0000000000000000   __rsp:0x000070000a10f7d0
      __r8: 0x00000000004f4004    __r9: 0x0000000000000001    __r10: 0x0000000000000000   __r11:0x0000000000000246
      __r12: 0x0000000003000000   __r13: 0x0000000000000000   __r14: 0x000070000a110098   __r15:0x000070000a1100a0
      __rip: 0x00007fff69bd13f8   __rflags: 0x0000000000000200   __cs: 0x000000000000002b   __fs:0x0000000000000000
    Thread 3:
    #  1  0x00007fff69b1817a in _mach_msg_trap + 0x0000000A (libsystem_kernel.dylib + 0x000000000000117a) 0x0000000000000000
    #  2  0x00007fff3c791fde in ___CFRunLoopServiceMachPort + 0x00000151 (CoreFoundation + 0x000000000003bfde) 0x0000000000000000
    #  3  0x00007fff3c79152d in ___CFRunLoopRun + 0x00000676 (CoreFoundation + 0x000000000003b52d) 0x000070000a18f0c0
    #  4  0x00007fff3c790c64 in _CFRunLoopRunSpecific + 0x000001CF (CoreFoundation + 0x000000000003ac64) 0x000070000a18fdc0
    #  5  0x00007fff3c790a70 in _CFRunLoopRun + 0x00000028 (CoreFoundation + 0x000000000003aa70) 0x000070000a18fe50
    #  6  0x0000000116223e7a in  (mbukernel + 0x0000000000010e7a) 0x000070000a18fe70
    #  7  0x00000001162204f5 in  (mbukernel + 0x000000000000d4f5) 0x000070000a18ff90
    #  8  0x000000011622529a in  (mbukernel + 0x000000000001229a) 0x000070000a1901c0
    #  9  0x0000000116225cda in  (mbukernel + 0x0000000000012cda) 0x000070000a190410
    10  0x0000000116225e11 in  (mbukernel + 0x0000000000012e11) 0x000070000a190460
    11  0x00000001115a0b1b in  (mso20 + 0x0000000000104b1b) 0x000070000a1904c0
    12  0x00000001119c37f4 in  (mso30 + 0x00000000000be7f4) 0x000070000a1904e0
    13  0x00000001119c2748 in  (mso30 + 0x00000000000bd748) 0x000070000a190aa0
    14  0x00000001119c15c4 in  (mso30 + 0x00000000000bc5c4) 0x000070000a190ac0
    15  0x00000001119c05d9 in  (mso30 + 0x00000000000bb5d9) 0x000070000a190b40
    16  0x0000000111957b40 in  (mso30 + 0x0000000000052b40) 0x000070000a190c00
    17  0x0000000111957775 in  (mso30 + 0x0000000000052775) 0x000070000a190df0
    18  0x00000001119550d0 in  (mso30 + 0x00000000000500d0) 0x000070000a190e30
    19  0x000000011194fc96 in  (mso30 + 0x000000000004ac96) 0x000070000a1910a0
    20  0x000000011194f9b4 in  (mso30 + 0x000000000004a9b4) 0x000070000a191150
    21  0x000000011194f6bd in  (mso30 + 0x000000000004a6bd) 0x000070000a1911a0
    22  0x000000011194f059 in  (mso30 + 0x000000000004a059) 0x000070000a191210
    23  0x00000001119fd8c7 in  (mso30 + 0x00000000000f88c7) 0x000070000a191260
    24  0x0000000111641afd in  (mso20 + 0x00000000001a5afd) 0x000070000a191290
    25  0x0000000111641e5d in  (mso20 + 0x00000000001a5e5d) 0x000070000a1923e0
    26  0x000000011163b5b1 in  (mso20 + 0x000000000019f5b1) 0x000070000a192410
    27  0x000000011165f264 in  (mso20 + 0x00000000001c3264) 0x000070000a192650
    28  0x000000011165efec in  (mso20 + 0x00000000001c2fec) 0x000070000a1926a0
    29  0x0000000111647073 in  (mso20 + 0x00000000001ab073) 0x000070000a1926d0
    30  0x0000000111647f8c in  (mso20 + 0x00000000001abf8c) 0x000070000a1928e0
    31  0x00000001116481a5 in  (mso20 + 0x00000000001ac1a5) 0x000070000a192a60
    32  0x0000000111631d27 in  (mso20 + 0x0000000000195d27) 0x000070000a192ad0
    33  0x0000000111631c0c in  (mso20 + 0x0000000000195c0c) 0x000070000a192c80
    34  0x000000011165c8b2 in  (mso20 + 0x00000000001c08b2) 0x000070000a192cd0
    35  0x0000000111572088 in  (mso20 + 0x00000000000d6088) 0x000070000a192d10
    36  0x0000000111571fd9 in  (mso20 + 0x00000000000d5fd9) 0x000070000a192d40
    37  0x000000011151e0dc in  (mso20 + 0x00000000000820dc) 0x000070000a192d80
    38  0x000000011151de49 in  (mso20 + 0x0000000000081e49) 0x000070000a192da0
    39  0x000000011151dd62 in  (mso20 + 0x0000000000081d62) 0x000070000a192e20
    40  0x00000001164b64c1 in  (WLMKernel + 0x00000000000184c1) 0x000070000a192e40
    41  0x00007fff6998fd53 in __dispatch_call_block_and_release + 0x0000000C (libdispatch.dylib + 0x0000000000002d53) 0x000070000a192e70
    42  0x00007fff69990dcf in __dispatch_client_callout + 0x00000008 (libdispatch.dylib + 0x0000000000003dcf) 0x000070000a192e90
    43  0x00007fff69993240 in __dispatch_queue_override_invoke + 0x000002FF (libdispatch.dylib + 0x0000000000006240) 0x000070000a192eb0
    44  0x00007fff6999ed26 in __dispatch_root_queue_drain + 0x00000145 (libdispatch.dylib + 0x0000000000011d26) 0x000070000a192f10
    45  0x00007fff6999f4bd in __dispatch_worker_thread2 + 0x0000005A (libdispatch.dylib + 0x00000000000124bd) 0x000070000a192f80
    46  0x00007fff69bd16dd in __pthread_wqthread + 0x0000026B (libsystem_pthread.dylib + 0x00000000000026dd) 0x000070000a192f90
    47  0x00007fff69bd1405 in _start_wqthread + 0x0000000D (libsystem_pthread.dylib + 0x0000000000002405) 0x000070000a192fd0
      __rax: 0x000000000100001f   __rbx: 0x0000000007000806   __rcx: 0x000070000a18efe8   __rdx:0x0000000000000000
      __rdi: 0x000070000a18f190   __rsi: 0x0000000007000806   __rbp: 0x000070000a18f040   __rsp:0x000070000a18efe8
      __r8: 0x000000000000a203    __r9: 0x00000000ffffffff    __r10: 0x0000000000000c00   __r11:0x0000000000000206
      __r12: 0x0000000007000806   __r13: 0x0000000000000c00   __r14: 0x000070000a18f190   __r15:0x0000000000000000
      __rip: 0x00007fff69b1817a   __rflags: 0x0000000000000206   __cs: 0x0000000000000007   __fs:0x0000000000000000
    Thread 4:
      __rax: 0x0000000002000170   __rbx: 0x000070000a216000   __rcx: 0x000070000a215b80   __rdx:0x000070000a196000
      __rdi: 0x000070000a216000   __rsi: 0x0000000000005f03   __rbp: 0x0000000000000000   __rsp:0x000070000a215b70
      __r12: 0x00000000810010ff   __r13: 0x0000000000000000   __r14: 0x000070000a216098   __r15:0x000070000a2160a0
    Thread 5:
    #  2  0x00007fff69b2a745 in _task_suspend + 0x00000050 (libsystem_kernel.dylib + 0x0000000000013745) 0x0000000000000000
    #  3  0x0000000116026700 in  (merp + 0x0000000000002700) 0x000070000a2981f0
    #  4  0x0000000116025efc in  (merp + 0x0000000000001efc) 0x000070000a298e30
    #  5  0x00000001160270ad in  (merp + 0x00000000000030ad) 0x000070000a298e50
    #  6  0x00007fff69bd2305 in __pthread_body + 0x0000007E (libsystem_pthread.dylib + 0x0000000000003305) 0x000070000a298f10
    #  7  0x00007fff69bd526f in __pthread_start + 0x00000046 (libsystem_pthread.dylib + 0x000000000000626f) 0x000070000a298f30
    #  8  0x00007fff69bd1415 in _thread_start + 0x0000000D (libsystem_pthread.dylib + 0x0000000000002415) 0x000070000a298f50
      __rax: 0x0000000000000000   __rbx: 0x0000000000000003   __rcx: 0x000070000a298148   __rdx:0x0000000000000018
      __rdi: 0x000070000a2981b8   __rsi: 0x0000000000000003   __rbp: 0x000070000a2981a0   __rsp:0x000070000a298148
      __r8: 0x000000000000ce07    __r9: 0x0000000000000000    __r10: 0x000000000000002c   __r11:0x0000000000000206
      __r12: 0x0000000000000003   __r13: 0x000000000000002c   __r14: 0x000070000a2981b8   __r15:0x0000000000000018
    Thread 6:
      __rax: 0x0000000002000170   __rbx: 0x000070000a31c000   __rcx: 0x000070000a31bb80   __rdx:0x000070000a29c000
      __rdi: 0x000070000a31c000   __rsi: 0x0000000000009703   __rbp: 0x0000000000000000   __rsp:0x000070000a31bb80
      __r8: 0x00000000001e4008    __r9: 0x0000000000000001    __r10: 0x0000000000000000   __r11:0x0000000000000246
      __r12: 0x00000000810010ff   __r13: 0x0000000000000000   __r14: 0x000070000a31c098   __r15:0x000070000a31c0a0
    Thread 7:
    #  2  0x00007fff699a4e0d in __dispatch_mach_send_and_wait_for_reply + 0x00000276 (libdispatch.dylib + 0x0000000000017e0d) 0x0000000000000000
    #  3  0x00007fff699a52ad in _dispatch_mach_send_with_result_and_wait_for_reply + 0x00000035 (libdispatch.dylib + 0x00000000000182ad) 0x000070000a39e860
    #  4  0x00007fff69c10161 in _xpc_connection_send_message_with_reply_sync + 0x000000B2 (libxpc.dylib + 0x000000000000a161) 0x000070000a39e8a0
    #  5  0x00007fff3df94aef in _kMDPlistBytesDeserializationCallbacks + 0x00001159 (Metadata + 0x0000000000008aef) 0x000070000a39e8f0
    #  6  0x00007fff6998fd53 in __dispatch_call_block_and_release + 0x0000000C (libdispatch.dylib + 0x0000000000002d53) 0x000070000a39e910
    #  7  0x00007fff69990dcf in __dispatch_client_callout + 0x00000008 (libdispatch.dylib + 0x0000000000003dcf) 0x000070000a39e930
    #  8  0x00007fff6999725d in __dispatch_lane_serial_drain + 0x000003A3 (libdispatch.dylib + 0x000000000000a25d) 0x000070000a39e950
    #  9  0x00007fff69997bdc in __dispatch_lane_invoke + 0x00000184 (libdispatch.dylib + 0x000000000000abdc) 0x000070000a39e9e0
    10  0x00007fff699a0090 in __dispatch_workloop_worker_thread + 0x0000025B (libdispatch.dylib + 0x0000000000013090) 0x000070000a39ea50
    11  0x00007fff69bd160b in __pthread_wqthread + 0x00000199 (libsystem_pthread.dylib + 0x000000000000260b) 0x000070000a39eb00
    12  0x00007fff69bd1405 in _start_wqthread + 0x0000000D (libsystem_pthread.dylib + 0x0000000000002405) 0x000070000a39eb40
      __rax: 0x0000000000000000   __rbx: 0x000000000400400e   __rcx: 0x000070000a39a6e8   __rdx:0x0000000000000000
      __rdi: 0x000070000a39a760   __rsi: 0x000000000400400e   __rbp: 0x000070000a39a740   __rsp:0x000070000a39a6e8
      __r8: 0x000000000001370f    __r9: 0x0000000000000000    __r10: 0x0000000000004000   __r11:0x0000000000000202
      __r12: 0x000000000400400e   __r13: 0x0000000000004000   __r14: 0x000070000a39a760   __r15:0x0000000000000000
      __rip: 0x00007fff69b1817a   __rflags: 0x0000000000000202   __cs: 0x0000000000000007   __fs:0x0000000000000000
    Thread 8:
    #  1  0x00007fff69b1a94e in ___ulock_wait + 0x0000000A (libsystem_kernel.dylib + 0x000000000000394e) 0x0000000000000000
    #  2  0x00007fff69991531 in __dispatch_wait_on_address + 0x00000086 (libdispatch.dylib + 0x0000000000004531) 0x0000000000000000
    #  3  0x00007fff69991d43 in __dispatch_group_wait_slow + 0x00000028 (libdispatch.dylib + 0x0000000000004d43) 0x000070000a41e2b0
    #  4  0x00007fff3df9493d in _kMDPlistBytesDeserializationCallbacks + 0x00000FA7 (Metadata + 0x000000000000893d) 0x000070000a41e2f0
    #  5  0x00007fff3df957ce in _kMDPlistBytesDeserializationCallbacks + 0x00001E38 (Metadata + 0x00000000000097ce) 0x000070000a41e440
    #  6  0x00007fff3df93250 in __MDPlistGetRootPlistObject + 0x000028B4 (Metadata + 0x0000000000007250) 0x000070000a41e4a0
    #  7  0x00007fff3df92fb4 in __MDPlistGetRootPlistObject + 0x00002618 (Metadata + 0x0000000000006fb4) 0x000070000a41e510
    #  8  0x00007fff3dab53a8 in _CSBackupSetItemExcluded + 0x00000238 (CarbonCore + 0x00000000000223a8) 0x000070000a420550
    #  9  0x00007fff512908b4 in pathURLPropertyProviderSetValues(__CFURL const*, __FileCache*, __CFString const* const*, void const**, void const**, long, void const*, __CFError**) + 0x00000230 (CoreServicesInternal + 0x000000000002a8b4) 0x000070000a4209a0
    10  0x00007fff51280c53 in __FSURLSetResourcePropertyForKey + 0x000000B5 (CoreServicesInternal + 0x000000000001ac53) 0x000070000a420e30
    11  0x00007fff3c84f294 in _CFURLSetResourcePropertyForKey + 0x00000057 (CoreFoundation + 0x00000000000f9294) 0x000070000a420ea0
    12  0x00007fff3c84f1fc in -[NSURL setResourceValue:forKey:error:] + 0x000000BB (CoreFoundation + 0x00000000000f91fc) 0x000070000a420ef0
    13  0x0000000111930102 in  (mso30 + 0x000000000002b102) 0x000070000a420f40
    14  0x0000000111ad6825 in  (mso30 + 0x00000000001d1825) 0x000070000a420f60
    15  0x0000000111ad66cc in  (mso30 + 0x00000000001d16cc) 0x000070000a421050
    16  0x0000000111aeb7dd in  (mso30 + 0x00000000001e67dd) 0x000070000a4210a0
    17  0x000000011192cd18 in  (mso30 + 0x0000000000027d18) 0x000070000a4210c0
    18  0x000000011192caf4 in  (mso30 + 0x0000000000027af4) 0x000070000a421120
    19  0x000000011192c88b in  (mso30 + 0x000000000002788b) 0x000070000a421170
    20  0x000000011192c7bf in  (mso30 + 0x00000000000277bf) 0x000070000a4211c0
    21  0x000000011192c746 in  (mso30 + 0x0000000000027746) 0x000070000a421210
    22  0x0000000111f5f95a in  (mso40ui + 0x000000000000f95a) 0x000070000a421270
    23  0x0000000111f5f84b in  (mso40ui + 0x000000000000f84b) 0x000070000a4212a0
    24  0x0000000111f5f507 in  (mso40ui + 0x000000000000f507) 0x000070000a4212f0
    25  0x0000000111f5e8a8 in  (mso40ui + 0x000000000000e8a8) 0x000070000a421370
    26  0x0000000111f5e524 in  (mso40ui + 0x000000000000e524) 0x000070000a421d10
    27  0x0000000111f5e337 in  (mso40ui + 0x000000000000e337) 0x000070000a421db0
    28  0x0000000111f5e2e8 in  (mso40ui + 0x000000000000e2e8) 0x000070000a421dd0
    29  0x0000000111f5e2a9 in  (mso40ui + 0x000000000000e2a9) 0x000070000a421e00
    30  0x00000001126600aa in  (mso99 + 0x000000000000f0aa) 0x000070000a421e10
    31  0x00007fff6998fd53 in __dispatch_call_block_and_release + 0x0000000C (libdispatch.dylib + 0x0000000000002d53) 0x000070000a421e70
    32  0x00007fff69990dcf in __dispatch_client_callout + 0x00000008 (libdispatch.dylib + 0x0000000000003dcf) 0x000070000a421e90
    33  0x00007fff69993240 in __dispatch_queue_override_invoke + 0x000002FF (libdispatch.dylib + 0x0000000000006240) 0x000070000a421eb0
    34  0x00007fff6999ed26 in __dispatch_root_queue_drain + 0x00000145 (libdispatch.dylib + 0x0000000000011d26) 0x000070000a421f10
    35  0x00007fff6999f4bd in __dispatch_worker_thread2 + 0x0000005A (libdispatch.dylib + 0x00000000000124bd) 0x000070000a421f80
    36  0x00007fff69bd16dd in __pthread_wqthread + 0x0000026B (libsystem_pthread.dylib + 0x00000000000026dd) 0x000070000a421f90
    37  0x00007fff69bd1405 in _start_wqthread + 0x0000000D (libsystem_pthread.dylib + 0x0000000000002405) 0x000070000a421fd0
      __rax: 0x0000000002000203   __rbx: 0x00000927c4d0a871   __rcx: 0x000070000a41e238   __rdx:0x0000000000000000
      __rdi: 0x0000000000000001   __rsi: 0x000060000134bfa4   __rbp: 0x000070000a41e270   __rsp:0x000070000a41e238
      __r8: 0x0000000000000001    __r9: 0x0000000000000000    __r10: 0x0000000000989680   __r11:0x0000000000000202
      __r12: 0x0000000000000000   __r13: 0x0000000000000001   __r14: 0x0000000000989680   __r15:0x000060000134bfa4
      __rip: 0x00007fff69b1a94e   __rflags: 0x0000000000000202   __cs: 0x0000000000000007   __fs:0x0000000000000000
    Thread 9:
      __rax: 0x0000000002000170   __rbx: 0x000070000a4a5000   __rcx: 0x000070000a4a4b80   __rdx:0x000070000a425000
      __rdi: 0x000070000a4a5000   __rsi: 0x0000000000006b03   __rbp: 0x0000000000000000   __rsp:0x000070000a4a4b70
      __r8: 0x00000000004f4006    __r9: 0x0000000000000001    __r10: 0x0000000000000000   __r11:0x0000000000000246
      __r12: 0x00000000000020ff   __r13: 0x0000000000000000   __r14: 0x000070000a4a50a4   __r15:0x0000000000000000
    Thread 10 crashed:
    #  1  0x0000000112672ab6 in  (mso99 + 0x0000000000021ab6) 0x0000000000000000
    #  2  0x000000011266e580 in  (mso99 + 0x000000000001d580) 0x0000000000000000
    #  3  0x000000011266dd3e in  (mso99 + 0x000000000001cd3e) 0x000070000a527bc0
    #  4  0x000000011151e2c9 in  (mso20 + 0x00000000000822c9) 0x000070000a527c30
    #  5  0x000000011151e0dc in  (mso20 + 0x00000000000820dc) 0x000070000a527c60
    #  6  0x000000011151de49 in  (mso20 + 0x0000000000081e49) 0x000070000a527c80
    #  7  0x0000000111530706 in  (mso20 + 0x0000000000094706) 0x000070000a527d00
    #  8  0x000000011151e0dc in  (mso20 + 0x00000000000820dc) 0x000070000a527d80
    #  9  0x000000011151de49 in  (mso20 + 0x0000000000081e49) 0x000070000a527da0
    10  0x000000011151dd62 in  (mso20 + 0x0000000000081d62) 0x000070000a527e20
    11  0x00000001164b64c1 in  (WLMKernel + 0x00000000000184c1) 0x000070000a527e40
    12  0x00007fff6998fd53 in __dispatch_call_block_and_release + 0x0000000C (libdispatch.dylib + 0x0000000000002d53) 0x000070000a527e70
    13  0x00007fff69990dcf in __dispatch_client_callout + 0x00000008 (libdispatch.dylib + 0x0000000000003dcf) 0x000070000a527e90
    14  0x00007fff69993240 in __dispatc
    2019-03-12T14:06:36+00:00
    How will Office be updated with the fix?  I hope it is soon cause I am standing still in water.
    Ricardo
