Mendeley Word Plugin Problem
2019-01-16T23:34:56+00:00
After the most recent autoupdate to Office, Word seems to have issues loading the Mendeley plugin.
When I run Word, I keep getting the following message:
File not found: libc.dylib ( 53) in Mendeley Plugin
Word version: 16.21
Mendeley version: 1.19.3
I tried uninstalling and reinstalling the plugin (and restarting between), I tried downloading and installing Word again.
Now the plugin appears to be installed but when I go to: references>insert or edit citation, I get the error message above.
Any ideas?
Thanks!
2019-01-18T13:43:17+00:00
*Screenshots are from the Dutch version.
After clicking the References tab in the Word Ribbon, an error menu pops up.
Click the (dotted) button at the right, will be 'Search errors' or something in English Word distribution, to open the Visual Basic Editor.
Then look up 'MacIpcClient' in the menu 'Project - MendeleyPlugin' at the upper left of your screen and double-click.
The following window will pop up, activate this window by clicking on the text.
Press ctrl (or cmd for mac) + F for the Find menu and click Replace... menu (or open Find and Replace with cmd + shift + H for mac).
Search for "libc.dylib" and fill in "/usr/lib/libc.dylib" in the Replace field and click 'Replace all'.
Click 'OK' on following pop-up windows.
Close Find and Replace menu.
Save the adjustments by clicking the floppy icon in the upper left and close window of Visual Basic Editor.
Finally, restart Word
2019-01-18T10:40:36+00:00
How I resolved the issue:
1.) You can download previous version here https://docs.microsoft.com/en-us/officeupdates/update-history-office-for-mac (scroll way down for a list of the previous versions). Then download the version you like, I just reverted to version 16.20 as mentioned above.
2.) Go to your applications folder and delete all Office applications.
3.) Download and install package. I also went offline so that it wouldn't check for a new version during installation (this might be unnecessary).
4.) Don't forget to deactivate auto-update: Go to help -> Check for updates -> Choose "Automatically Check" or "Manually Check".
145 additional answers
    2019-02-05T16:22:34+00:00
    Worked for me thanks so much van den Burg!!
    2019-02-05T18:03:23+00:00
    I tried van den Borg's method: replacing 'libc.dylib' with absolute path '/usr/lib/libc.dylib' and it worked!
    Thank you for that van den Borg.
    However, I just want to emphasise that for some unknown reason I could not use find and replace function within Virtual Basic Editor. I simply copied the whole MacIpcClient script to another text editor and did the replacement there.
    2019-02-05T20:52:33+00:00
    Citation plugin issues on OSX Mojave
    We are aware that users who upgraded to OSX Mojave have been experiencing issues with Microsoft Word and the Mendeley Citation plugin.
    While Mendeley Desktop does not yet support OSX Mojave we have been in touch with Microsoft to resolve this issue. This issue was caused by an update to Microsoft Word, and we've identified a fix for this which will be available in an experimental release in mid-February.
    Please check back here for exact dates soon.
    says: https://service.elsevier.com/app/answers/detail/a\_id/28441/session/L3RpbWUvMTU0OTM5OTgzMi9nZW4vMTU0OTM5OTgzMi9zaWQvZlU4aGljT0dXc1I4SzNldE9zQ1MwaklGMENna1RnSTEyNk1ZZjlsakJ6WXpON0JqR2hmZ0JPSGpoQ1R2bmgzTVAlN0VTdmt2JTdFWmRyMFZfZExLU1A5d0lUNGNRR1glN0VYc3IxMGs4bzZQdGNEVTJsalM5QklUclY1RTVBJTIxJTIx//supporthub/mendeley/p/10941/
