Power Point slide show keep jumping back to prior slide
2018-11-09T12:31:18+00:00
New MacBookPro.
Just installed Office365.
Using PP to view slides from Multimedia Exercises for Basic Japanese Grammar.
One has to read/respond/click-to-hear-answer/click-to-go-to-next-page/next-question.
If I am idle for a random period of time, it pops back to a prior slide.
Sometimes it happens quite soon after clicking onto a new slide, so it is not a general timeout feature.
Also, the slide it pops back to changes as on proceeds further.  It breaks the basic flow logic of the presentation as to get back, you end up activating some next state you don't necessarily want to.  IE, getting back to read the question makes it think you want to see the answer, but you are not yet ready to see it.
My question is: is this a bug in the slides, or a bug in the programme?
The slides force one to open read-only, and I don't know much about PP so I don't know where to look to see if there is some time-based thing which kicks in if I am idle.
2018-11-20T22:23:48+00:00
Hi All,
I'd like to share a summary for the issue here which will benefit other community members.
Symptoms:
Power Point slide show may jump automatically back to prior slide
Environment:
  1. OS: Mojave 10.14.1 (18B75).
  2. PowerPoint version: 16.18 (Wait on a slide for about 30 seconds in full screen presentation mode, the slide will automatically skip to a previous slide)
  3. PowerPoint version: 16.19 (181109) (Some customers fix the issue by upgrading to 16.19, but the other ones still have the issue) (The 16.19 may make the issue idle time from 30 seconds to 10 minutes)
  4. The issue happens to all files
  5. The issue happens in full screen presentation mode but not in presenter view mode.
  6. The issue disappears when all the customers trying to do a screen recording.
Workaround:
Play the presentation in presenter view mode.
Assessment:
Please update the Office to the latest 16.21 version to get the fix.
Rena
[Updated by Rena Yu MSFT, 08:16 AM Jan 18, 2019(UTC)]
2018-12-14T22:48:45+00:00
Hi all,
Thank you all for providing related videos and logs. We have narrowed down the root cause, and we're working with Apple for a fix.
In the mean time, we have added a temporary solution in the next update.
As a current workaround, if you have more than 1 graphics cards on your device, you can do the following:
    (1) Go to System Preferences
    (2) Go to Energy Saver
****(3) Uncheck Automatic graphics switching(If you do not see this option, you only have 1 graphics card)
We completely understand your frustration with this problem. We appreciate your patience.
Best,
Ming
107 additional answers
    2018-11-15T04:03:38+00:00
    Hi Pastr D,
    Thanks for confirming the result and sharing the information. This helps a lot.
    The Version 16.19.0 (Build 18110915) has just been released as the production version. It is also the same version 16.19.0 (Build 18110915) for Insider slow.
    Nice to hear that the issue has been fixed by upgrading to that version. We will deliver to other members to check whether they can fix that as well.
    Rena
    2018-11-15T04:06:14+00:00
    Hi All,
    As Pastr D has confirmed that upgrading to Version 16.19.0 (Build 18110915) fixes the issue, please check whether this solution taking effect by your side as well.
    You can go to Help tab > Check for updates to update the version.
    Please let us know any updates at your convenience.
    Rena
    2018-11-15T17:06:51+00:00
    Rena -
    I've spent most of the morning testing my PowerPoint with 16.19.
    I think that it is less unstable with 16.19 than it was with 16.18, but it still exhibits the problem of covering the current slide with a previous slide. With 16.19 it seems to require a longer idle time to kick in. At one point it took over ten minutes of idle time.
    I have also discovered that using QuickTime Player to make a Screen Recording seems to keep the problem from happening. I don't know why, but in the several instances where I had the problem occur - when I then tried to make the same thing happen while recording, nothing happened. (Except that I had a long recording of nothing happening.)  I let the slide sit idle for over twenty minutes at a time and it was as stable as it used to be in the old days - before 16.18.
    To summarize:
    1. 16.19 does not fix the problem completely, but improves things.
    2. Running QuickTime Player and making a Screen Recording seems to keep the problem from happening.
    PastrD
