Power Point slide show keep jumping back to prior slide
2018-11-09T12:31:18+00:00
New MacBookPro.
Just installed Office365.
Using PP to view slides from Multimedia Exercises for Basic Japanese Grammar.
One has to read/respond/click-to-hear-answer/click-to-go-to-next-page/next-question.
If I am idle for a random period of time, it pops back to a prior slide.
Sometimes it happens quite soon after clicking onto a new slide, so it is not a general timeout feature.
Also, the slide it pops back to changes as on proceeds further.  It breaks the basic flow logic of the presentation as to get back, you end up activating some next state you don't necessarily want to.  IE, getting back to read the question makes it think you want to see the answer, but you are not yet ready to see it.
My question is: is this a bug in the slides, or a bug in the programme?
The slides force one to open read-only, and I don't know much about PP so I don't know where to look to see if there is some time-based thing which kicks in if I am idle.
2018-11-20T22:23:48+00:00
Hi All,
I'd like to share a summary for the issue here which will benefit other community members.
Symptoms:
Power Point slide show may jump automatically back to prior slide
Environment:
  1. OS: Mojave 10.14.1 (18B75).
  2. PowerPoint version: 16.18 (Wait on a slide for about 30 seconds in full screen presentation mode, the slide will automatically skip to a previous slide)
  3. PowerPoint version: 16.19 (181109) (Some customers fix the issue by upgrading to 16.19, but the other ones still have the issue) (The 16.19 may make the issue idle time from 30 seconds to 10 minutes)
  4. The issue happens to all files
  5. The issue happens in full screen presentation mode but not in presenter view mode.
  6. The issue disappears when all the customers trying to do a screen recording.
Workaround:
Play the presentation in presenter view mode.
Assessment:
Please update the Office to the latest 16.21 version to get the fix.
Rena
[Updated by Rena Yu MSFT, 08:16 AM Jan 18, 2019(UTC)]
2018-12-14T22:48:45+00:00
Hi all,
Thank you all for providing related videos and logs. We have narrowed down the root cause, and we're working with Apple for a fix.
In the mean time, we have added a temporary solution in the next update.
As a current workaround, if you have more than 1 graphics cards on your device, you can do the following:
    (1) Go to System Preferences
    (2) Go to Energy Saver
****(3) Uncheck Automatic graphics switching(If you do not see this option, you only have 1 graphics card)
We completely understand your frustration with this problem. We appreciate your patience.
Best,
Ming
107 additional answers
    2018-11-11T01:58:29+00:00
    Hi Neo.
    I am not creating the presentation.  It is a read-only one accompanying a book I purchased.
    My assumption is that the authors/editors/reviewers of this book would have found/fixed any issues in the content, as it is essential to the book.
    I find that I only run into the problem on my MacBookPro (laptop) not my Mac Pro (Desktop).
    I thought it might be an OS version issue, but turns out both were same 10.14 version.
    The laptop is the most recent PP version, as I freshly installed Office365 and then checked for an update.  I just checked the Desktop version: no updates available.  I had left it overnight displaying "slide 10".  The laptop version will revert to showing either the first slide, or "slide 8" (not the real slide #) after ~60 seconds.  Desktop: never acts weird.
    I'll PM you with a link to the file in question.  I am not having any luck cut&pasting images nor uploading images for inclusion here.
    Both desktop and laptop were 10.14, and both are now being upgraded to see if this changes things...
    2018-11-11T02:07:49+00:00
    Hi Pastr.  My title does imply "prior" but the text explicitly specifies "a prior".
    Mine does use the first slide initially, but once I progress sufficiently far into the deck, it picks up another one to annoy me with for a while.
    My Desktop on 10.14 does not have the behaviour, but my laptop on 10.14.1 does.
    I am about to upgrade the Desktop to see if that is the trigger for this mis-feature.
    BTW: one the Laptop, I just select the presenter view to view and adjust the screen size maximally for the current slide and, as you observed, avoid the problem.  That is sufficient workaround for me, but apparently no good for you providing an alternate view?
    Anyway, sounds like we will get to the bottom of this shortly.
    2018-11-11T02:19:47+00:00
    My attempt to cut&paste images did not result in the image making it into the post.
    On the Desktop, I was 10.14.
    I thought I had upgraded the laptop to 10.14.1, but not.  It is at 10.14 also, wanting me to upgrade.
    Both are on the most recent version of powerpoint.
