Power Point slide show keep jumping back to prior slide
2018-11-09T12:31:18+00:00
New MacBookPro.
Just installed Office365.
Using PP to view slides from Multimedia Exercises for Basic Japanese Grammar.
One has to read/respond/click-to-hear-answer/click-to-go-to-next-page/next-question.
If I am idle for a random period of time, it pops back to a prior slide.
Sometimes it happens quite soon after clicking onto a new slide, so it is not a general timeout feature.
Also, the slide it pops back to changes as on proceeds further.  It breaks the basic flow logic of the presentation as to get back, you end up activating some next state you don't necessarily want to.  IE, getting back to read the question makes it think you want to see the answer, but you are not yet ready to see it.
My question is: is this a bug in the slides, or a bug in the programme?
The slides force one to open read-only, and I don't know much about PP so I don't know where to look to see if there is some time-based thing which kicks in if I am idle.
2018-11-20T22:23:48+00:00
Hi All,
I'd like to share a summary for the issue here which will benefit other community members.
Symptoms:
Power Point slide show may jump automatically back to prior slide
Environment:
  1. OS: Mojave 10.14.1 (18B75).
  2. PowerPoint version: 16.18 (Wait on a slide for about 30 seconds in full screen presentation mode, the slide will automatically skip to a previous slide)
  3. PowerPoint version: 16.19 (181109) (Some customers fix the issue by upgrading to 16.19, but the other ones still have the issue) (The 16.19 may make the issue idle time from 30 seconds to 10 minutes)
  4. The issue happens to all files
  5. The issue happens in full screen presentation mode but not in presenter view mode.
  6. The issue disappears when all the customers trying to do a screen recording.
Workaround:
Play the presentation in presenter view mode.
Assessment:
Please update the Office to the latest 16.21 version to get the fix.
Rena
[Updated by Rena Yu MSFT, 08:16 AM Jan 18, 2019(UTC)]
2018-12-14T22:48:45+00:00
Hi all,
Thank you all for providing related videos and logs. We have narrowed down the root cause, and we're working with Apple for a fix.
In the mean time, we have added a temporary solution in the next update.
As a current workaround, if you have more than 1 graphics cards on your device, you can do the following:
    (1) Go to System Preferences
    (2) Go to Energy Saver
****(3) Uncheck Automatic graphics switching(If you do not see this option, you only have 1 graphics card)
We completely understand your frustration with this problem. We appreciate your patience.
Best,
Ming
107 additional answers
    2018-11-19T15:00:40+00:00
    Hi Everyone,
    Just wanted to let everyone know that some users are reporting that the issue is fixed on 16.19. If you're still experiencing the issue, please update to the latest version and try again.
    If the issue persists, we'd really appreciate a video of the issue. As some users are indicating that the issue could not be reproduced when recording the screen, please use your phone to record the behavior.
    Regards,
    Sheen
    2018-11-19T20:29:38+00:00
    Sheen, it's not fixed with 16.19 (at least not for me).  I'm running 16.19 (181109) on Mojave 10.14.1 (18B75).
    I've created a video (as requested) of the issue, and made it available here.
    I've also included a copy of the presentation that I used.  To be clear, I'm certain that it has nothing to do with the presentation, but wanted to provide it for parity testing.
    Also, in case it wasn't mentioned elsewhere, the behavior that I see consistently is that it will jump back to the slide that you first started presentation mode from.
    2018-11-19T22:16:03+00:00
    Hi Jake,
    Thanks for helping us collect the video and sample file. Now we can know clearly how the issue looks like.
    In the meantime, can you also help us confirm the information below:
    1. To narrow down the issue related to any startup apps, extensions, custom font, some caches etc. on your Mac, please run Mac in safe modeto see whether the issue persists in this mode.
    2. To narrow down the issue related to any 3^rd^ party add-ins inside the PowerPoint app, please go to Insert tab > My Add-ins and check whether there’s any add-ins installed. If so, temporarily removing them to see the result.
    If the issue persists, please help us get a sample process log at your convenience. To do that:
    When the issue happens, navigate to Finder>Applications>utilities>activity monitor, double click activity monitor, under the process name column, double click Microsoft PowerPoint, then click Sample. I have sent you a private message as well via this link, you can provide us the log file there.
    Rena
