A family of Microsoft spreadsheet software with tools for analyzing, charting, and communicating data
Hi Jeremy,
Could you please provide the requested information for us?
Ran
When I have excel open, even a tiny spreadsheet, and move the window around the screen there is severe lag. The window can keep moving around the screen for a few seconds after I have stopped moving the mouse. I am running windows 10 with all updates installed and Office 365 with all updates installed.
The lag gets worse when connected to an external high res monitor.
This problem does NOT occur with any other application window which can be moved around the screen as fast as I like with no lag.
I am running Surface Pro 3, i5 8Mb Ram with all updates installed.
Hi Jeremy,
Ran
Hi Ran
The Windows version is 1803
The build is 17134.112.
I'm very busy with work at the moment but will try to get the video as soon as I can.
Thanks.
Jeremy
Hi I have some time today to look at the problem but can not see how get a video of the issue. Your private message showed me how to upload a video once collected but did not tell me how to actually collect it, is there a video utility I should use?
Jeremy
Hi Jeremy,
You can capture the video using your phone as we also need to check your mouse movement with the issue.
Ran
Hi, Ran I sent you a video a couple of weeks ago did you get it ok?
