Word is not saving changes to documents
2018-05-10T08:29:45+00:00
I use microsoft one and i noticed the changes were not being saved online. So i did a save as version on my desktop and renamed it and it still did not save! I have no idea where to locate the changes I have made these past 24 hours. I look at recent docs and there are zero changes to my document showing for yesterday even though I was editing all day. I have no clue why my documents aren't saving and I need to find the document i lost!
    2018-09-02T11:16:08+00:00
    Hi Swaggette
    Thank you so much for your input regarding my problem. I checked the files that were updated around that time on the hard disk that I used. Unfortunately, the file was not there.
    2018-09-09T06:36:50+00:00
    I also am having the same problem. I am a microsoft certified professional, and I use word for work.
    IT's terribly costly and has caused me to send out reports that are missing data to my clients.
    As you can see, microsoft does not seem to know, or care. Typical.
    I recommend saving your document as an adobe pdf as soon as it is finished. That will lock in the changes you have made.
    I know it's a clunky work around, but hopefully someone at MS will wake up and figure it out in the meantime.
    2018-09-10T08:44:42+00:00
    I'm sorry to hear your problems but relieved it's not just me! Did you begin to experience these problems recently or has it been longer term? Are you running the latest versions/patches of W10 and Word? Are you logged into OneDrive? Do you get this just from USB or does it happen on your C: drive, network drive, etc.? Is it particular users or just yourself?
    It's a nasty little gremlin that has the potential for massive impact. Not saving when one clicks on the save button is just a danger that really shouldn't happen - in my experience (35 years IT, 13 in an academic environment) this has never happened before in any operating system or package that I've worked with. We have vocational students as well as academics, teenagers to 70+ year-olds, full-timers, part-timers, etc. spread over 3 universities so there's a wide spread of IT experience and even if we could contact them, what could we say? "Save your work regularly but don't rely on clicking on the save button because it doesn't always work"?
    We can't even rely on the PDF option that you suggested. By definition, our users have very complicated documents - dissertations that contain tables, figures, questions, format changes, heavy use of Styles, captions, cross referencing, academic referencing add-ins and more - and opening these using Word reads some of the complicated stuff in as diagrams and loses some of the embedded navigation referencing. We can really only rely on PDFs for the users to be able to copy the raw text they've typed back into the document that was supposed to have saved when they clicked on the save button (better than nothing, but a solution to a problem that just shouldn't  exist).
    We're just hoping that installing the latest image that contains all safe updates and patches resolves the problem. I'll keep you posted if we get any progress, in the meantime good luck!
    2018-09-10T20:05:08+00:00
    Thanks for your tip. - for me it is too late.
    2018-09-10T20:09:11+00:00
    Thanks for your mail. I appreciate it.
    I've tried to fix it the way you discribed, but it did not work. I think the data are overwritten already.
    I just have to accept it, i guess...
    Marcel
