Word is not saving changes to documents
2018-05-10T08:29:45+00:00
I use microsoft one and i noticed the changes were not being saved online. So i did a save as version on my desktop and renamed it and it still did not save! I have no idea where to locate the changes I have made these past 24 hours. I look at recent docs and there are zero changes to my document showing for yesterday even though I was editing all day. I have no clue why my documents aren't saving and I need to find the document i lost!
    2018-05-16T07:39:30+00:00
    Hi Marcel,
    We would like to know more about your concern regarding the Word files. Kindly answer the questions below:
    • Have you tried checking your OneDrive account?
    • Did you save the edited files on a different folder?
    If you saved the file with "Save As" option, there's a possibility that you changed the file name unnoticed. Try to search for other Word files on your computer and see if the edited files are present.
    Hi Virfranz Man
    I had not check my OneDrive Account before you asked, so I did now. But unfortunatly the wordfiles aren't there.  I did not save my edited files on a different folder ( I already checked that). I saved it in the Documents folder.
    The other options you mention doesn't work either. I did not save the file with the 'save as...' option
    I find it rather strange that Word does not store the processed files as they should
    Thanks for your help
    Marcel
    2018-05-16T02:02:45+00:00
    Hi Marcel,
    2018-05-14T18:18:27+00:00
    Hi Virfranz Man
    I have the same problem.
    I made a document in Word2016 (outlook365) on 2-25-2018 on my pc. It had 12 pages.
    I copied this document to my laptop while travelling to the USA. In the USA I made changes to this document almost daily. No problems were noticed.
    To be safe I sent the docment (now about 30 pages) after a few days with my gmail-account to my own mailbox.
    Yesterday I came home and moved (not copied!)  the document (now 50 pages) to an USB-stick and copied it to my harddrive.
    The document was now only 12 pages!
    I opened my e-mailbox to restore the document I made when it was 30 pages: and that file has also just 12 pages. In both cases the date is set on 2-25-2018. That was the document I made at first!
    Both my laptop and PC runs on WIndows 10. My laptop has Word 2007.
    On my laptop I saved my document under /documents.
    On my PC I save the document on a WD My Cloud Mirror.
    Of course: I should have saved it directly in the cloud, but unfortunatly I didn't.
    What is reason that the changes in my doc-files have disappeared?
    Marcel Beijer
    The Netherland
    2018-05-11T02:27:36+00:00
    Hello Melsss,
    We would like to know more about your concern regarding the files you're trying to save. Kindly answer the questions below:
    • When did the issue start?
    • Have you made any changes or installed any updates prior to the issue?
    • Are you experiencing the issue with other Office applications?
    • What is the version of Office are you using?
    • Are you saving the edited files to an external drive?
