Physical Therapy Project
2019-02-05T00:08:30+00:00
I am now starting a physical therapy project.
Here are my relationships so far:
So far the queries I have built are working good and giving me nice results.
My first question is basically about concatenating data.
Example 1:  I have 35 therapists. All therapists have at least one degree. About 16 therapists out of the 35 therapists have two or three degrees. What is the best way to concatenate their degrees?  By using the concatenate & in a string? My problem is that there are various amounts of degrees, so I'm not finding it easy to concatenate their degrees unlike their names - for example, FullName: [tFirst] & " " & [tLast] Or is there another way to handle this? I don't plan on creating a search by degree, but that may occur in the future.
Example 2:  The therapists and their Status. Some therapists are Per Diem (on call), some therapists are part time, and so on. Some therapists have more than one status (a few are part time and per diem). What's the best way to handle this so their status appears on one line? Would waiting until building the reports be best before handling this, and putting it in reports? I will be having a search by status, especially for the Per Diems therapists.
Example 3:  Some therapists work 1 day a week; some work 2 days; some 3; some 4; some 5; and some work 6 days a week. I have the days entered, but I won't get to building a table with therapists and their days until later. I'm assuming I will have to figure out a way similar to the above two examples to have the days show up nicely. Or should that also wait until I do reports? There will be a search for days by Therapy Type (ie, Physical Therapy, Occupational Therapy, Speech Therapy and Wound Therapy).
I hope my question is making sense. Thank you for your time and help.
Microsoft 365 and Office | Access | For home | Windows
2019-02-26T18:15:54+00:00
Hmm, just realized you need your WHERE statement to include both Visit and Clinic...
SELECT tblClinicTherapist.ctTherapistID, tlkpClinic.cName, [tFirst] & " " & [tLast] AS FullName
FROM (tlkpTherapist INNER JOIN (tlkpClinic INNER JOIN tblClinicTherapist ON tlkpClinic.cClinicID = tblClinicTherapist.ctClinicID) ON tlkpTherapist.tTherapistID = tblClinicTherapist.ctTherapistID) INNER JOIN tblClinicTherapistVisit ON tblClinicTherapist.ctClinicTherapistID = tblClinicTherapistVisit.ctvClinicTherapistID
WHERE (((tblClinicTherapistVisit.ctvVisitID)=[Forms]![frmSearch]![cboVisit]) AND ((tlkpClinic.cClinicID)=[Forms]![frmSearch]![cboClinic]))
ORDER BY tlkpTherapist.tLast;
59 additional answers
    2019-02-22T01:50:03+00:00
    When you hit the "search" button nothing happens. It's very odd.
    2019-02-22T01:58:20+00:00
    I would make sure there is still an Event Procedure attached to the button as it sounds like it got disconnected.
    2019-02-22T02:34:00+00:00
    That was the first thing I checked. It's very strange. I checked it again just now, and it does still have this as an Event:
    Private Sub btnSearch_Click()
    On Error Resume Next
            Dim strWhere As String
            Dim strSQL As String
            Dim lngLen As Long
        'Number field example. Do not add the extra quotes.
        If Not IsNull(Me.cboVisit) Then
            strWhere = strWhere & "([vVisitID] = " & Me.cboVisit & ") AND "
        End If
        If Not IsNull(Me.cboTherapist) Then
            strWhere = strWhere & "([tTherapistID] = """ & Me.cboTherapist & """) AND "
        End If
        lngLen = Len(strWhere) - 5
            If lngLen <= 0 Then
                strSQL = strSQL
                DoCmd.OpenReport "rptVisitTherapist", acViewReport
                DoCmd.Maximize
            Else
                strWhere = Left$(strWhere, lngLen)
                strSQL = strSQL & " WHERE " & strWhere
                DoCmd.OpenReport "rptVisitTherapist", acViewReport, , strWhere
                DoCmd.Maximize
                Reports![rptVisitTherapist].Filter = strWhere
                Reports![rptVisitTherapist].FilterOn = True
            End If
    End Sub
    2019-02-22T02:38:59+00:00
    I just played with it a little more.
    The search button works if the form is not filled out, ie no choices selected, and the correct report opens up. The search button also works if Visit is selected but no Therapist is selected, and the correct report also opens up. When Therapist is selected, the button does not work. So maybe the problem is indeed what I originally thought a few posts above this, maybe related to FullName: [tFirst} & " " & [tLast] or something in the Row Source???
